Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-22-2009   #1 (permalink)
drunkenmagnum
drunkenmagnum's Avatar
drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light
Send a message via AIM to drunkenmagnum
What are my pluggs telling me?
I use to know this like the back on my hand but look at the coloration of my old plugs and tell me what you think. this was under 14PSI for a little over 9k miles. No misfires until recently. Replaced them yesterday and the car runs smoother @ ideal. I think they look as is I have been running a little lean but the A/F has been good.
Ignore the one covered in oil. had a little leak after putting a different valve cover on. this was not going into the cylinder.
__________________
196 hp
194 fpt @ 10psi - Before the rebuild
"My d!ck feels like corn"-Dane Cook
R.I.P 7thgencivic.com
Type-S Fuel Injectors for sale.
WTB: 02-04 ep3 (si) rear brake assembly
T.E.A.R.S crew member #1
Car for Sale
drunkenmagnum is offline   Reply With Quote
Sponsored Links
Old 03-22-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: What are my pluggs telling me?
shouldnt you be changing plugs every 2-3k miles (5k max) with a turbo anyway? its only $2 a piece. also looks like your plugs are running too hot. maybe consider switching one size colder plug. what i see in the pic is usually caused by advanced ignition timing, lean a/f, vacuum leaks, or problem with the cooling system (your coolant level and water pump okay?)
if you say the a/f is good, then just switch to a one step colder plug. stick with copper ofcourse.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 03-22-2009   #3 (permalink)
drunkenmagnum
Yeah, Went with a different plug this time. Funny you should say cooling system, it has been running a bit warm lately. Not too hot though but making me worry about it a little. I recently turned the boost back to ten just for safety. And yes, went a little far on these plugs.
I need a new tune though as evidence from all of my recent threads....
__________________
196 hp
Car for Sale
Old 03-22-2009   #4 (permalink)
gearbox
Super Moderator
it seems to be a common problem that nobody with a turbo can keep the engine cool enough. Is it that the stock radiator is not good enough to cool the extra heat made by turbocharging the motor? or is it something else. i never could figure out why, and i read threads about running hot all the time and coolant spilling out the reservoir.
__________________
www.lubecontrol.com
Member 1025782
Old 03-23-2009   #5 (permalink)
drunkenmagnum
The turbo itself puts a huge strain on the cooling system but many of us wind up with leaking or blown headgaskets and the first signs are a overheating engine. I think the OEM cooling system will work just fine running on 10 PSI. I still have the OEM system and for years never had a single heating issue until a blown gasket.
Do you have a link to the pictures of what different pluggs look like with different problems. I remeber seeing it online a while back but cant find it.
__________________
196 hp
Car for Sale
Old 03-23-2009   #6 (permalink)
gearbox
Super Moderator
couldnt find any but check google maybe. if you were burning coolant you would have a white residue on the plug. so headgasket is prolly fine.
__________________
www.lubecontrol.com
Member 1025782
Old 03-23-2009   #7 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
yea looking in the back of the chiltons book, it looks like your running hot as gearbox said. Reccomendation is check for correct plug heat range, over advanced ignition timing, lean fuel mixture, intake manifold vaccume leaks, sticking valves and insufficent engine cooling. Juding from what you have said I think its the last one.
04 Honda Civic is offline   Reply With Quote
Old 03-24-2009   #8 (permalink)
drunkenmagnum
thats the thing, it could be ten different problems...
Car runs fine now though
__________________
196 hp
Car for Sale
Old 06-22-2009   #9 (permalink)
Megabyte
New Member
Megabyte is an unknown quantity at this point
if you want to run cooler. And you should. Run a set of cooler plugs. Like it was already stated. But up to a set of NGK Iridiums with the cooler temp. Run a dual core half rad with a slim fan. And oil cooler with a switchable fan hooked up to your rad fan. And slap a meth injection setup. But for that extra lil bit... You should go with an msd igntion set up to ensure proper spark at high rmps. It will prevent coil saturation. And possibly change your oil to Royal purple. Start by doing some of these and see where it takes you. Good luck
Megabyte is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
450+ Hp Goal
Oil in coolant overflow
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
Help- Built engine makes less power than before (dyno graph)
Site Supporters
aluminum radiator
Honda car spoilers
