Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 12-27-2008   #1 (permalink)
JA7
New Member
JA7 is an unknown quantity at this point
Turbo help
i got a 04 civic ex dont know much about turbos can anyone tell me if i have to buy anything more wit this kit.
Garrett GT20 turbo (GT25 turbo for the D17 kits) w/ internal wastegate set to 6 PSI.
Does not require any engine modification.
Bolt-on installation.
Safely produces a 56% gain in horsepower on stock engine internals. This means you will get about 180 to 205 total horsepower, depending on what D Series Civic you have (D15, D16, or D17).
Cast manifold that comes preassembled on Garrett turbo.
Down pipe and gasket.
Polished charge piping.
High-flow intercooler.
Stainless steel braided oil line and fittings.
Stainless steel braided water lines for turbo cooling.
Blow off valve.
Choose from 2 different fuel systems (described above), depending on what your needs are.
Rising rate fuel pressure regulator (not included or needed on 7th Gen Civics).
Heat shield.
High-performance air intake and filter.
Oil return hose and oil pan fitting.
All hardware, pressure lines, hoses, clamps, and couplers.
Installation instructions & injector control settings.
5 year warranty on cast parts, 1 year for accessories, and the full Garrett manufacturer's warranty for the turbo.
JA7 is offline
Sponsored Links
Old 12-30-2008   #2 (permalink)
civicsrcool
Super Member
civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned
Re: Turbo help
if your wondering why you havent gotten a reply its because these type of questions are asked every other day. use the SEARCH button on the top of the screen. thats your best source. or read the STICKIES in the turbo section.
__________________
here is my pos
civicsrcool is offline
Closed Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
