Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-26-2008   #1 (permalink)
Maple50175
Senior Member
Maple50175 is an unknown quantity at this point
Turbo gurus's I got a few questions
ok so I installed a turbo kit. overall install went ok. I finished up today and well, of course i have a slight oil leak from the stupid oil line in the back of motor, and coolant but that's easy to fix and will do tomorrow.
My T25 garret turbo spins when I start my car and is working. Car idles and starts perfect. Using emanage.
ok so the vacuum lines go like this:
Vacuum line from the motor (next to throttle body to):
Boost Gauge//Blow Off Valve//Emanagevacc
Are these 3 things that only use the vacuum lines? and is it hooked up this way?
I have NO boost at all. and I don't get why. All my IC fittings are tight as hell I cant figure any leaks.....
As far as my wastegate, its an internal wastegaste. Now theres a vac line that goes from the wastegate actuator to the Turbo. Thats correct right?
SO what else could be a reason why I have No boost!?
__________________
02 Civic Coupe Boosted 8PSI
Maple50175 is offline   Reply With Quote
Sponsored Links
Old 07-26-2008   #2 (permalink)
FGCOUPE
Diamond Member
FGCOUPE's Avatar
FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all
Re: Turbo gurus's I got a few questions
From intake manifold to master brake cylinder
From intake manifold to boost guage (OEM and/or Aftermarket)
From intake manifold to OEM BOV
From intake manifold to fuel pressure regulator
From actuator to charge pipe direct (if solenoids are bypassed)
BOV Youll have a split "Y" to route from:
From intake manifold to Aftermarket BOV
From charcoal canistor to "Y" to aftermarket BOV
From "Y" to aftermarket BOV
From charcoal canistor to fuel purge
Also check to line to your boost controller
__________________
http://www.civicforums.com/forums/signaturepics/sigpic54055_4.gif
1989 Skyline GTST w/RB25DET swap
FGCOUPE is offline   Reply With Quote
Old 07-26-2008   #3 (permalink)
Maple50175
Senior Member
that was confusing.
__________________
Old 07-26-2008   #4 (permalink)
FGCOUPE
Diamond Member
FGCOUPE's Avatar
first just check the lines from the turbo/actuator to the boost solenoids and/or to the charge pipe.
Check the lines from the BOV regardless if its OEM or Aftermarket.
Recirc pipes are fitted
look around and see if theres anything disconnected then get back?
__________________
Old 07-27-2008   #5 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Have you driven the car yet?
First thing I would check is those crappy worm clamps on your charge pipe connectors. My guess is you've got a hellacious boost leak somewhere.
You vac setup sounds fine although I would give the e-manage (it's going to the emanage MAP sensor) it's own source because you want that to be as accurate as possible. But your current setup should not be preventing the turbo from building boost.
The only other thing is that the wastegate actuator is stuck and it's bleeding off all of the exhaust so the turbo can't get enough exhaust to build pressure. Back the rod in and out to make sure it moves freely.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 07-27-2008   #6 (permalink)
Maple50175
Senior Member
hey update!!!
So yeah I got the car going, I took off my old exhaust since my car is so slow it was dragging and took it for a spin and yeah boost works for sure! I was just going too slow like 10 mph lol.
But wow i can tell a diff. I do need to get it tuned, im using the kids who i bought it from tune or whatever i do have a few problems
the coolant line has a hole in it. going to turbo SO i gotta find a line, anyone know where I can get a single one?
Autometer boost gauge never reads any boost do you have to calibrate it? or something please tell me how??
I drove it and wow totally a diff, I LOVE that bov sound so loud.
I wanna get the exhaust work done tomorrow if i have time. Should I keep the cat? or remove it? I have the greddy sp2 catback
let me know i have more questions but will ask once I get these. lol
__________________
Old 07-28-2008   #7 (permalink)
speedfoos
speedfoos's Avatar
Which coolant line has a hole in it? There at least 6 in the engine ba y.
Autometer gauge is mechanical or electrical? If it's mechanical, you probably kinked the line somewhere getting it from the engine bay, thru the firewall and in to the gauge. Check that first.
If you don't need to pass emissions ever, then dump the cat.
__________________
www.7thgenhonda.com
Old 07-28-2008   #8 (permalink)
FGCOUPE
Diamond Member
FGCOUPE's Avatar
autometer guage....just connect the high pressure line straight to the intake manifold.
as for the turbo, unless you plan on upgrading the turbo leave the dump pipe alone. Otherwise youll see boost spikes come up.
Get it TUNED, and spend the money here, A good tune will keep you running properly. Cheap out here and kiss your engine/turbo good bye!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
