Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-03-2008   #1 (permalink)
Mex
Ultimate Member
Mex's Avatar
Mex is a jewel in the rough Mex is a jewel in the rough Mex is a jewel in the rough
Send a message via AIM to Mex
Question about removing turbo pipes from turbo...
I'm slowly returning my car to stock in preparation to sell. I'm ready to install the stock resonator/air box, but don't yet have the stock exhaust manifold/oil pan. What I want to know is, can I remove only the intake pipes from the turbo to reinstall my stock air intake? (pipes highlighted in red) I'm referring only to the air filter pipe leading into the turbo, and the 3 pipes leading to the throttle body. This would give me the room necessary to install the stock intake. I can't think of any possible damage that would be done by having the turbine simply blow air out into the atmosphere, unless it contains exhaust gases, but I may be overlooking something. Are the exhaust gases contained strictly to the downpipe? I also know to put a simple filter covering over the intake hole so no rocks or anything get into the turbine and damage it. Advice/comments anyone?
Mex is offline   Reply With Quote
Sponsored Links
Old 07-03-2008   #2 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
Re: Question about removing turbo pipes from turbo...
I wouldn't do it for any extended period. You risk overspooling the turbo with no resistance against it....
Is that an sfp manifold?
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Old 07-04-2008   #3 (permalink)
Mex
Ultimate Member
Mex's Avatar
thanks for the reply... it's a stafford fabrications kit (one of the few who actually got theirs)
what is meant by overspooling? would this do damage to the bearings? also for a while now I've been running the turbo without the wastegate actuator rod attached so I won't build up any boost. is that anything different?
Old 07-05-2008   #4 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
I've read about it, never seen it happen. Basically, the theory is, the more rpm and load the engine sees, the harder the turbo works. If there's no resistance against it, it just freespins. So yeah, if it's dumping and creating no boost, I would say it's about the same thing.
__________________
-or-
Old 07-05-2008   #5 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of
I'll buy your chargepiping....
__________________
Rufus is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
