Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-17-2008   #46 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
Re: Help- Built engine makes less power than before (dyno graph)
Stock intake? For real? Holy shit, dude....
Seriously, I'm surprised this is the first of problems you've seen. Consider yourself lucky your motor is still in tact. You need to start from scratch and do shit right....
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Sponsored Links
Old 06-17-2008   #47 (permalink)
dopes6070
dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned
Send a message via AIM to dopes6070
I was actually trying to blow the stock intake mani and it held 18PSI LOL. maybe I got a freak one... I wouldnt trust it long term tho haha.
__________________
Me - 2001 K20A2 Civic & 2005 Acura RL
GF - 2008 Civic Sedan
dopes6070 is offline   Reply With Quote
Old 06-18-2008   #48 (permalink)
drunkenmagnum
drunkenmagnum's Avatar
drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light
Send a message via AIM to drunkenmagnum
Yes I have the Stock IM on there and no I am not changeing it out until I get more cash. It should hold 12psi.
I think i may be dumping too much methanol in there and I ned to back that off some. I know it took you a few Engines before you got yours right too Andy and only through trial and error did you finally get one right that makes incredable power. I am not trying to break records but 90% of the people that boost on here have stock IM's and only a small handfull have had issues. I have already backed the boost down and i will have it so the Methanol comes in @ 12psi instead of 9-10 to prevent "soaking"
__________________
196 hp
194 fpt @ 10psi - Before the rebuild
"My d!ck feels like corn"-Dane Cook
R.I.P 7thgencivic.com
Type-S Fuel Injectors for sale.
WTB: 02-04 ep3 (si) rear brake assembly
T.E.A.R.S crew member #1
Car for Sale
drunkenmagnum is offline   Reply With Quote
Old 06-18-2008   #49 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
Lol, I had to learn on my own. I didn't have anyone who knew shit to give me advice. But it's whatever. Do what you want, but there's a reason you're making no power. So yeah, don't listen and keep being cheap. Piggyback & stock im FTL.
__________________
-or-
Old 06-18-2008   #50 (permalink)
emjay
Super Member
emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough
PICKED UP MY KPRO andy !!! cam gear ordered for 180 from hondata dealer in toronto ... as of intake manifold , im going with the d16y8 till next yr when i go EL style manifold, bigger turbo, and JDM fabtech 400 ftmfw -- am i doing things properly andy??my car is going in 2 weeks .. drunkenmagnum ...u don't need much money to change ur IM man ... the d16 will run u around 150 max and its good for 250-300 .. might be a lil restrictive but so is the turbo anyway and that can be upgraded next yr, u wanna be safe first then make power.. if im restricted to 250 with a fully built d17, then im not gona be sad, i have a rocking setup that will hold 350-400 .. jus gotta get the right parts .. with another 3 grand i can get to 400 ... JDMfabtech, bigger turbo and el style mani ... the rest of my setup is 9.5/10 wit the way im plannin it ..
i chose the turbo route because of civicforums instead of a swap, so the least i can do is to listen to the pros about their advice and follow their footstep, people like andy who u said has been thru many motors and learnt, im on my first one and its pulling strong for 11 months @ 196 whp with a piggy back .. im not gona argue and think that what im doing is right wen d17 turbo beasts are telling me otherwise
__________________
boosted 1.7eL -- whp: classified
emjay is offline   Reply With Quote
Old 06-18-2008   #51 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
Are you doing it right? Well you're definitely on the right path with a good computer. I mean, define what "right" means...
Upgraded fuel pump and a computer with properly sized injectors and an im that won't crack apart is all you really need to get started...
__________________
-or-
Old 06-18-2008   #52 (permalink)
emjay
Super Member
doing it right means doing it right, don't go big without standalone, safety, i dunno reliability, not blow head gaskets, jus do it right ... i dunno .. NO HEADACHE = doing it right to me
i have a walbro, i have kpro, im gona get bigger injectors, and im getting the d16y8 .. is there any other intake manifolds other then the jdm fabtech fuck so fukin expensive
__________________
Old 06-18-2008   #53 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
None that I know of. It's possible to get a performer X and see if it will fit btw the head and firewall but I'm not sure. To be honest, nobody knows what the d16 im will do on a d17 when pushed.
__________________
-or-
Old 06-18-2008   #54 (permalink)
emjay
Super Member
fuck man im worried about my IM now .. tuner and shop said it should be good for 250-300 there are d16s out there doing that daily on that IM but shit man im still worried
__________________
Old 06-18-2008   #55 (permalink)
emjay
Super Member
__________________
Old 06-18-2008   #56 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned
Send a message via AIM to ronaldo9
Does KMS still make an intake mani or was that just a prototype? Either way I'm sure it won't be cheap or much cheaper than JDM fabtech.
ronaldo9 is offline   Reply With Quote
Old 06-18-2008   #57 (permalink)
emjay
Super Member
kms ? never heard of them ? there are d16s running 400s out there ... im not too worried at all i jus got off the fone with my tuner he's like i've tuned guys out of here with 4 and some change .. the Y8 is a very strong IM
__________________
Old 06-18-2008   #58 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
y8 should be fine, I wouldn't be too worried about it.
__________________
-or-
Old 06-19-2008   #59 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
From what I understand, the KMS intake was a piece of shit. Rufus bought one recently from a guy here and promptly sold it on Ebay after it showed up. Apparently it's just an aluminum box with some vac ports and some runners TIG'd on to it. I think it went for a final price of around $150.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 06-19-2008   #60 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Yep..I bought it off rufus.....Just the CNC flange alone is worth $150 bucks to me.......I can always have someone hack this one up & redo it or cut the flange off & start from scratch. Plus....I am in the process of having alot of it rewelded and I have already made it shine x10....I'm in the process of 1000 grit & a buffer It's almost chrome......
I see most of our flow issues in the head & camshaft....our intake/exhaust ports are so small it's ridiculous. All I really see that intake manifold for is to up the boost for a build. That box will flow plenty under alot of boost, it won't break, and it seriously looks dope all cleaned up! For $150 bucks that eliminates my $1000 need for a "good" intake manifold.....I can use that to get kpro. I'm debating wether or not to put it on now or wait until the build. It's not like I can boost anymore on my stock motor and I don't really think I'll see real gains until more boost is met.......so it might just sit pretty for motor build!
We'll see!
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is online now   Reply With Quote
Tags
2005 , air , dyno , engine , fuel , graph , honda , injectors , leaning , makes , power , ratio , rsx , srt , stock , torque
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
