Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-13-2008   #31 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
Re: Help- Built engine makes less power than before (dyno graph)
If that was the case, it's not the norm. To remove this ad, register today for free or log in if already registered!
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Sponsored Links
Old 06-13-2008   #32 (permalink)
dopes6070
dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned
Send a message via AIM to dopes6070
Well its not the norm I think because i modded the stock fpr LOL. and most people arent willing to do that type of thing.
__________________
Me - 2001 K20A2 Civic & 2005 Acura RL
GF - 2008 Civic Sedan
dopes6070 is offline   Reply With Quote
Old 06-13-2008   #33 (permalink)
emjay
Super Member
emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough
what happens if u don't go returnline and are going for big power and just tune with 750cc and kpro ? i know pressure can increase ... but if it hasn't already ..it won't randomly would it?
__________________
boosted 1.7eL -- whp: classified
emjay is offline   Reply With Quote
Old 06-13-2008   #34 (permalink)
dopes6070
I believe the stock fuel pressure is 43 psi so if you are forcing 15 psi into the intake manifold the boost works against the fuel pressure because remember the pump has to push fuel through the injectors and into the manifold to go with the boost. So you really only have 28 psi of fuel pressure which isnt nearly enouph. thats why everyone uses a 1:1 reglator which would bring it to 58 psi under boost. I just eliminated having to run a return line. I just needed a boost ref line going to the tank which I ran through my interior so it was hidden.
__________________
Old 06-13-2008   #35 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
well for all practical purposes the leaner the more HP he will make. ASSuming the tuner wasnt letting it detonate while he tuned it. It just seems like something else is wrong. If i were to guess timing may be off(cam or ignition)???? I guess my first question is what all was changed during the rebuild other than injectors and pistons? As for the must have standalone argument ehhh ... save that for a rainy day....... As far as the rising rate FPR it is true they are the way to go in most cases. In my case i tuned mine @ 7psi without the boost reference at all. Mine in fact is capped with out a vacuum line hooked up. Any fuel management is only as good as the person setting it up. Or in my case only as good as the amount of time spent setting it up.
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 06-14-2008   #36 (permalink)
02fpcivic
Diamond Member
02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light
To a point lean is mean(and very dangerous), until you have severe detonation, then the motor fights itself. Think about it, the pre-ignition is the reason why you bend/throw rods, hammer the bearings out, break ring lands, etc..
__________________
JDM Fabtech
02fpcivic is offline   Reply With Quote
Old 06-15-2008   #37 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
Quote:
true, but like i said assuming he wasnt getting any detonation.
__________________
Or
DIY Head gasket
Old 06-15-2008   #38 (permalink)
02fpcivic
Diamond Member
Well who knows what this tuner is doing, hehe. Most of the places Ive been to have no idea about tuning obd2 piggy-back systems and the ones that do want nothing to do with them at boost levels this high. I think going k pro tuned at a hondata certified shop would probably cure this situation. I'd go through the car thoroughly before doing so to make sure everything was up to par.
__________________
JDM Fabtech
Old 06-15-2008   #39 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
Now if only people would listen...
__________________
-or-
Old 06-17-2008   #40 (permalink)
drunkenmagnum
drunkenmagnum's Avatar
drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light
Send a message via AIM to drunkenmagnum
Well I am pretty sure something else is the issue here (the A/F is fine). I haven’t been driving the car lately and have been keeping an eye on the stats just to monitor that nothing is out of line. Next month I want to schedule time with a different tuner just to see what we might be able to do differently and get some input on this from another source and see what he says about the fuel problem or if there is one.
IT just seems to me that with those injectors, even with the stock fuel pump, that i should be able to put down no less than 200whp.
The car itself has been running great - minus any respectable power.
__________________
196 hp
194 fpt @ 10psi - Before the rebuild
"My d!ck feels like corn"-Dane Cook
R.I.P 7thgencivic.com
Type-S Fuel Injectors for sale.
WTB: 02-04 ep3 (si) rear brake assembly
T.E.A.R.S crew member #1
Car for Sale
drunkenmagnum is offline   Reply With Quote
Old 06-17-2008   #41 (permalink)
emjay
Super Member
Quote:
i listen i listen i won't do it unless i do it right
Old 06-17-2008   #42 (permalink)
drunkenmagnum
My installer said the SRT-4 injectors went in without a issue but everyone else has had to mod there clips it seems to make them work. is it possible they could have been installed incorrectly or might i need a resistor box?
Dont think this is an issue, just throwing it out there.
__________________
196 hp
Car for Sale
Old 06-17-2008   #43 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
No, SRT-4 injectors are high impedance just like the stock D17 and RSX ones, so you don't need a resistor box. The stock Honda clips will 'fit' the SRT-4 injectors, they just don't lock in firmly to make a secure connection. Basically they could pop off if you went over a big bump or something to jar the engine enough to pop a clip, but that doesn't sound like your issue.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 06-17-2008   #44 (permalink)
drunkenmagnum
the way the boost drops off as the RPM and power increases, is that normal? havent found any real leaks but i want to make sure some is not creeping out.
__________________
196 hp
Car for Sale
Old 06-17-2008   #45 (permalink)
speedfoos
speedfoos's Avatar
Definitely sounds like you have a boost leak somewhere. Stock intake mani may be leaking. The rumor is that it's not guaranteed to much good over 12psi. 15psi could have caused a small breach and you now leak pressure from it. All you silcone joints are good? Using T-clamps or standard worm-clamps?
If your turbo has a pressure port on it, it may be worth hooking a boost gauge up to it and comparing the pressure drop between the compressor and what's registering at the IM. Might help pinpoint a leak.
__________________
www.7thgenhonda.com
Tags
2005 , air , dyno , engine , fuel , graph , honda , injectors , leaning , makes , power , ratio , rsx , srt , stock , torque
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
