Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-17-2008   #31 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of
Re: Overheating/Turbo/Slim Fans
I sold the entire turbo kit. No more headaches To remove this ad, register today for free or log in if already registered!
__________________
Rufus is offline   Reply With Quote
Sponsored Links
Old 01-08-2009   #32 (permalink)
stand clear
New Member
stand clear is an unknown quantity at this point
start with using a high scfm fan,then if it does change the radiator to a koyo or fluidyne full front
stand clear is offline   Reply With Quote
Old 01-08-2009   #33 (permalink)
Rufus
Rufus's Avatar
Or you can just sell it all
__________________
Old 04-15-2009   #34 (permalink)
djaysin04
New Member
djaysin04 is an unknown quantity at this point
i have the identical problem you do, all the same symptoms except i get a ton of overflow from the reservoir and i have a koyo radiator...... but i think i found out what the problem is. two things... first one may or may not really but much of a factor, but if you dont use dex cool coolant or just a type of coolant thats made for aluminum radiators, little clogs can build up which may lead to slightly more overheating. anyways im sure as everyone knows a radiator has coils going back and forth stack on top of one another very tightly. what happens often especially in the case of having a turbocharge system is the coolant gets too hot leading to more pressure. in some cases the coolant can get so hot that it will cause one of the lines of the coils to expand, crushing the one above and below it. this will eventually stop the flow of coolant until the coolant gets hot enough and builds enough pressure to where it finally burst through filling ur reservoir tank/ overflowing. also if you have ever had your heater on to help keep the car cool you'll notice the heater stops working suddenly even when the car is overheating. this is because the flow of coolant has stopped. ive had my car turbo-ed for 4 yrs and never had a problem until recently, but ive been using just regular universal prestone coolant. i really dont think the type of coolant makes that great of a difference but maybe it happened when i raced my car to hard in 98 degree weather?? what im going to do now is get my radiator pressure tested at a radiator shop and buy another koyo radiator if it is damaged. pictures on the way soon =D
djaysin04 is offline   Reply With Quote
Old 04-15-2009   #35 (permalink)
Rufus
Rufus's Avatar
I would be surprised if it was the radiator to be honest.
__________________
Old 04-29-2009   #36 (permalink)
djaysin04
New Member
lol it wasnt the radiator, i have a cracked head gasket. i use synthetic oil and it was hard to tell if there was water in it, but after taking off the valve cover it was obvious. i order a mls cosmetic head gasket so we'll see if that does the trick. if not im done with my car too. do i have to use photobucket to upload pics or can i do it straight from here?
Old 05-05-2009   #37 (permalink)
Rufus
Rufus's Avatar
Photobucket is WAY easier
__________________
Tags
10 , 2006 , ac , aem , b16a , civic , fan , fans , fic , heating , honda , overheating , overheats , psi , slim , turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
