Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-24-2009   #31 (permalink)
civic-king
Super Member
civic-king's Avatar
civic-king is an unknown quantity at this point
Send a message via Yahoo to civic-king
Re: Rotrex Supercharger?
here is their technical website:
http://www.rotrex.com/index1.htm
civic-king is offline   Reply With Quote
Sponsored Links
Old 02-25-2009   #32 (permalink)
jamis33
You Stay Classy, San Diego
jamis33's Avatar
jamis33 is a jewel in the rough jamis33 is a jewel in the rough jamis33 is a jewel in the rough jamis33 is a jewel in the rough
Send a message via MSN to jamis33
looks really great. Make sure you post up your progress!
__________________
EM2CREW and ES1CREW Stickers available PM ME!!!!
http://www.civicforums.com/forums/94...-stickers.html
thanks EYGER!!!! You saved my tein flex!!!!
jamis33 is offline   Reply With Quote
Old 02-25-2009   #33 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned
Send a message via AIM to lordhelmet
So are you going to try this?
lordhelmet is offline   Reply With Quote
Old 02-25-2009   #34 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Curious to see how this works out. All you need is a bracket where the AC went, a longer belt, and a custom crank pulley.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 02-25-2009   #35 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
Seems like you could get electric power steering out of an EP and throw the retrex where the power steering is and keep ac.
Old 02-25-2009   #36 (permalink)
speedfoos
speedfoos's Avatar
Probably not as there really isn't enough room for the unit in that spot without hitting the exhaust mani on one side or making the snout poke past the strut tower making it impossible to route the belt to the crank pulley.
__________________
www.7thgenhonda.com
Old 02-25-2009   #37 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
Good point. We'll have to wait and see.
Old 02-25-2009   #38 (permalink)
civic-king
Super Member
civic-king's Avatar
i wanted to place in P/S pump spot. great place for mounting.
problem: rotrex SC only rotate in clockwise direction. P/S pump rotates counter-clockwise.
i've contacted rotrex, they say no, they do not have a counter rotation available. so, i have to engineer a reverse idler pully. SC will most likely have to be gear or chain driven, (noisey)
any ideas how to reverse a pully direction otherwise?
Old 02-25-2009   #39 (permalink)
civic-king
Super Member
civic-king's Avatar
i've done the measurements. SC will fit great in P/S pump area! just rotates backwards.....
Old 02-25-2009   #40 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
Would there be enough room to make a bracket that flips the charger over in order to create the correct rotation? It'd be kind of ghetto but...
Old 02-25-2009   #41 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
double post
Old 02-27-2009   #42 (permalink)
civic-king
Super Member
civic-king's Avatar
i was thinking this might work. i don't have ABS so there is some room; but the motor mount is kinda in the way. also, SC must be mounted on the engine block assembly. it'd be a strange and combersome bracket. i'm thinking a gear-driven mechinism with a pully is the only way. i.e. mount the pully where the p/s pump is, have a small spline shaft that runs to another gear. basicly think of two balls stacked on top of each other. when the bottom ball rotates, it causes the ball on top to turn the oppisite direction...
Old 04-03-2009   #43 (permalink)
jamis33
jamis33's Avatar
hey have u made any progress
__________________
Tags
08 , buy , civic , comparison , driven , forum , honda , jackson , kit , kraftwerksusa , power , racing , rotrex , steering , supercharger , turbo , wiki
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
