Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-09-2008   #91 (permalink)
02fpcivic
Diamond Member
02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light
Re: Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
I put on 3/8 npt bung for a vac manifold, and one for the brake booster. You still use your factory hardware for everything else fuel rail, etc. These wont trip cels on piggyback systems. To remove this ad, register today for free or log in if already registered!
__________________
JDM Fabtech
02fpcivic is offline   Reply With Quote
Sponsored Links
Old 02-09-2008   #92 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Awesome.....That IM is a thing of beauty! PM'D....
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Old 02-12-2008   #93 (permalink)
02fpcivic
Diamond Member
The two topmounts are done. I'm just waiting on my parts from Honda to make sure everything is aligned properly before sending anything out. I used most of the stuff I had on hand when putting my car together so I didnt have enough hardware for final mockup. The stuff should be here tomorrow. I also have the plenum for the N/A manifold all put together so maybe tomorrow I will start fitting the runners together.
__________________
JDM Fabtech
Old 02-12-2008   #94 (permalink)
filipinop1405
Diamond Member
filipinop1405's Avatar
filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light
Send a message via AIM to filipinop1405 Send a message via MSN to filipinop1405 Send a message via Yahoo to filipinop1405
DAMN Gerry those look great!!!!!
filipinop1405 is offline   Reply With Quote
Old 02-12-2008   #95 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Gerry.... tip before you send these out.... weld a 1/8 NPT fitting in next to the stock MAP sensor port so you can mount an AEM sensor (assuming people buying them are using a screw in high pressure MAP). Its an incredibly tight squeeze to get a 3/8 T fitting next to the throttle to mount both the map sensor and the Vac manifold.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Old 02-12-2008   #96 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
gerry question on those manifolds. Do you make your own TB plates or do you have someone else mill them?
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 02-12-2008   #97 (permalink)
bomerman19
Super Member
bomerman19's Avatar
bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned
Wow Gerry!
Those two top mounts look great! I can't wait to see that N/A Mani
bomerman19 is offline   Reply With Quote
Old 02-13-2008   #98 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Please don't do the 1/8" NPT in that location on mine! My GM 3-BAR is not a screw-in! If you do put one in, I'd put it somewhere close to the passenger side as there's more room over there to hang my GM sensor (which is where it is already).
All that being said Gerry, they look fucking awesome!!!!
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 02-13-2008   #99 (permalink)
02fpcivic
Diamond Member
You guys can mount those 1/8 map sensors on your vaccuum manifolds. It doesnt effect the readings as long as you supply the vaccuum manifold with a 3/8 line. no sense jamming it all into one spot and making it hard on yourselves. I have yet to have a problem doing it that way.
__________________
JDM Fabtech
Old 02-13-2008   #100 (permalink)
02fpcivic
Diamond Member
Tfnaaf, right now I am working with a guy at night on these. We write the programs on cad/cam software. He helps me set up the machine and I am the dummy that stands around and feeds it. There is a lot to know with cnc machinery and I'm still learning the basics. I'm not fluent enough to trust myself with a $250k machine just yet, hehe. I am very hands-on so I still have control over everything that I do, quality is very important to me.
__________________
JDM Fabtech
Old 02-13-2008   #101 (permalink)
exturbo6
Post Master General
exturbo6's Avatar
exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future
Send a message via AIM to exturbo6
sweet gerry! thanks a million...cant wait to get it!
exturbo6 is offline   Reply With Quote
Old 02-13-2008   #102 (permalink)
speedfoos
speedfoos's Avatar
Good stuff on the MAP port Gerry. I've got mine running off my vac mani currently and am glad to know I don't have to change it around at all.
__________________
www.7thgenhonda.com
Old 02-13-2008   #103 (permalink)
tuningmycivic
Ultimate Member
tuningmycivic's Avatar
tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all
Send a message via AIM to tuningmycivic Send a message via Yahoo to tuningmycivic
those are pretty damn spiffy-lookiing...but i have to ask, what are the additional flanges for??
__________________
T.E.A.R.S. Member #5 All turbo builds end in T.E.A.R.S
My turbo build thread 169.39 WHP/157.15 WTQ
Quote:
Originally Posted by TRIZ View Post
you cant just add a k20 to a car like an extra plastic brick to your lego people house.
“Great pain is, as the teacher of great suspicion, the ultimate liberator of the spirit.” - Friedrich Nietzsche as quoted by Mark Twight of Gym Jones
tuningmycivic is offline   Reply With Quote
Old 02-13-2008   #104 (permalink)
filipinop1405
Diamond Member
if your talking about the ones that are sitting on the mani.. i think they are gaskets.. but i might be wrong.
Old 02-13-2008   #105 (permalink)
FoSho
Super Member
FoSho's Avatar
Can I use an upgraded map sensor w/ a piggyback like emanage?
__________________
75mm Throttle Body
Tags
8998 , fabtech , intake , jdm , jdmfabtech , jdmfabtechcom , lego , long , manifold , na , steve , tube , wwwjdmfabtechcom
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
