Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-31-2007   #1 (permalink)
stand clear
New Member
stand clear is an unknown quantity at this point
Exhaust Temperature
What Sort Of Exhaust Temperature Should I Be Seeing On A 350whp B16a ? To remove this ad, register today for free or log in if already registered!
stand clear is offline   Reply With Quote
Sponsored Links
Old 08-31-2007   #2 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold
Send a message via AIM to DsevenEm2
Re: Exhaust Temperature
really hot temperature...why?
go out and buy one of those laser temp. reader things from napa..point it at ur muffler or actually... sumwhere near ur manifold and get a reading.
but why do u need to know?
__________________
"We are defined by the choices we make"
MMI Gradutate - 11-21-08
Yamaha 5-star~Honda Level1~Mercury/Mercruiser Level1~Suzuki EntryLevel1~Volvo/Diesel EntryLevel1 -- Certified
Next step: United StatesCoast Guard - BC 12-06-08
DsevenEm2 is offline   Reply With Quote
Old 08-31-2007   #3 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
install an EGT gauge. Anything getting beyong 1400 is too hot.
Its not a matter of HP, its a matter of the tuning. You can control your EGTs with the AFR and the ignition timing
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Old 09-25-2007   #4 (permalink)
FLAVOR247
New Member
FLAVOR247's Avatar
FLAVOR247 is an unknown quantity at this point
Im assuming your not boosted, and if not I dont know why you would post up if you do not have any info that would benifit boosted setups.
He wants to know about the exhaust gas temperature to know where is a safe point for him to be running.
An EGT gauge (pyrometer) uses a probe installed in the path of the exhaust flow, either in the Y pipe, Down pipe or exhaust manifold and will give the temparatures as they change under different driving conditions. As Boilermaker1 already stated, anything above 1400 is hot, resulting in a lean condion meaning the engine is not getting enough fuel. Idealy you would want to be around 1100 and as you go WOT, and under boost the temps will rise but you want to tune so that the engine never really sees the 1400 mark or never goes beyond that.
You can adjust the fuel ratio by using different methods. You can use an engine managment system, or a FPR, and using adequete sized per injectors setup will help eliminate lean condions a well. Tuning so that you run a bit rich will result in lower EGTs.
Adjusting the timing really wont lower the EGTS, but retarding it will make the engine perform safer under lean conditions (high EGTs)
FLAVOR247 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
