Honda Civic Forced InductionHonda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
FPR - Is this how a fuel pressure regulator works?
First off, I've got an aeromotive FPR on my car with SLPs return fuel kit, and I can adjust the fuel pressure with the hex screw on the unit, no problem. I'm using this in conjunction with a turbo. What I find odd is, the fuel pressure doesn't seem to rise with the psi of boost, but instead rises when i use the gas.
I have it set so when my car is idle, it's at 45psi. when i start to accelerate, whether hard or soft, it jumps to about 53-55psi. this is without any boost (wastegate open). when i'm using my turbo, i'll accelerate and get to 5-6psi of boost, but here's where i'm confused. my fuel pressure only increases like 0.5psi per pound of boost. if i accelerate without boost, i'm at 55psi. if i accelerate up to 6psi, i'm at like 57psi. I was under the impression that the pressure regulator would increase the fuel pressure like 2-3psi per pound of boost. Am I mistaken, or does something not sound right? So it's that, and the immediate +10psi jump i get just by using the gas pedal, that make me think something's not right.
Sponsored Links
for all I know, everything's connected right. I have no problem adjusting the fuel pressure using the fitting on top of the FPR.
Just recently I fixed the problem of not being able to adjust it at all because I left the stock fuel pressure regulator in the pump! all my hoses seem to be connected right... i have to wonder if it's a problem with the FPU itself... anyone know where i can get a replacement for cheap?
Anyone else with an aeromotive fuel pressure regulator? I also want to know if it's common for it to jump like 8-10psi when going from idle to just giving it a little gas...
