Go Back   Honda Civic Forum > GENERAL > Honda Civic Forced Induction
Honda Civic Forced Induction Honda Civic Forced Induction - When you've done all you can to your Honda Civic Cold Air Intake and upgraded exhaust, it's time to step up to Honda Civic turbochargers and Honda Civic superchargers.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-10-2007   #1 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Oil Lines
I'm gonna be running the dezod v3 kit. I plan to use an adapter off the block with 1/8 BSP male, with a female 1/8 BSP port for the stock sending unit. Also has two 1/8 NPT threads. This is made of steel for stability. I will use one 1/8 NPT port for the oil feed line & the other on a short hose to a Y-Adapter meant for a VW with M10x threads& two 1/8 NPT.
Instead of using the M10x threads for the VW sending unit I am using the M10 to 1/8 NPT Adapter then into the 12" Hose.
Then hose then goes to the back of my block on the adpater with a turbo oil feed line. My question is the two open 1/8 NPT ports are great.
I'm installing an electric oil pressure sending unit & oil temp sending unit. Do you think I will get accurate readings from the temp gauge?
Also the temp unit actually threads in deeper in one port than the other. In the port it threads all the way down, when you look in the block
the temp unit is blocking almost half of the opening. In the other port the temp unit threads in about 3-4 threads, the unit barely touches the opening the block.
Which port do you think if any will work the best? Here's some pictures.
Block with all units installed (Temp sender threaded all the way in)
Up close with temp sender threaded all the way in
Up close with temp sender unit threaded 3-4 threads
Up close of block opening (temp sender is threaded all the way down & is blocking a larger portion of the opening)
and the adaptor on the back of the block (tunertoys.com)
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is online now   Reply With Quote
Sponsored Links
Old 02-10-2007   #2 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
No you wont. Oil temp is best measured from the oil pan, so you get the reading of the oil going IN to the engine, not coming out of it. The static temperature in is the one you want to know.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Old 02-12-2007   #3 (permalink)
FoSho
Super Member
FoSho's Avatar
ok, do you know any sites online with the 1/8 NPT weld in fitting for aluminum?
Also, you think that adapter off the block is decent?
__________________
75mm Throttle Body
Old 02-13-2007   #4 (permalink)
Boilermaker1
Jap-Euro Fusion
Try jegs or summit racing
I wouldn't hang all that stuff off the back of the block, something's liable to break with all that weight hanging on it. use the T, remote mount everything else to something solid.
__________________
2002 Civic
Old 02-13-2007   #5 (permalink)
FoSho
Super Member
FoSho's Avatar
Alright, thats what I was afraid of. I'm gonna use the dezod 1/8 BSP to 1/8 NPT Adapter then to the dezod supplied t-fitting. One line to the turbo feed, the send using my 12" line, into my Y-fitting, with my stock & aftermarket sending units. Not much weight on the back of the block and no interruption in feed to the turbo. I think it should be a clean install.
Or what do you think of the Greddy Oil Filter Adapter?
I also was wondering how the effecient the dezod turbo was on draining oil. I've seen alot of leaking turbos as a result. Do I need a line restrictor?
__________________
75mm Throttle Body
Tags
95 , civic , feed , gage , hang , install , installing , line , lines , oil , turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
How to run oil and water lines for 14b turbo? kronickz Honda Civic DIYs and Civic Tech Chat 1 07-20-2006 03:53 PM
Steel braided oil lines civic01vtec Forced Induction and Swaps 5 07-14-2005 10:56 PM
WTB: STainless Oil Lines!!! REDchirp Florida 4 06-20-2004 04:40 PM
Turbo oil lines! Barney Honda Civic DIYs and Civic Tech Chat 5 02-03-2003 07:17 PM
Turbo Question - Oil Lines Grey Honda Civic DIYs and Civic Tech Chat 9 08-03-2002 03:23 PM
User Login
Our Partners
used new
Top 10 Threads
Rotrex Supercharger?
Honda Superchargers??
Port-n-polished dezod*updated*
Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
Oil in coolant overflow
450+ Hp Goal
d17a1 turbo
Overheating/Turbo/Slim Fans
lookin for 400whp on b16a
ITBs with a turbo setup???
Site Supporters
aluminum radiator
Honda car spoilers
