Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 3 Weeks Ago   #16 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Noob question about lowering
what i meant was, shocks/struts and springs are separate entities. the springs on most cars can be removed as a separate piece whereas most aftermarket coilovers are a single piece design with shock and spring all one piece. so yes technically a stock shock and spring (when they are assembled together) is also a coilover. but the difference is you can change either spring or shock by itself, rather than as one complete part. To remove this ad, register today for free or log in if already registered!
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Sponsored Links
Old 3 Weeks Ago   #17 (permalink)
Ironliftr3
New Member
Ironliftr3 is an unknown quantity at this point
Gottcha..thanks for the clarification!
One more question, then I'm done (famous last words!).
When removing my shocks/springs, do I need to use a spring compressor before I remove the assembly, or does the assembly remove, then I use a spring compressor when separating the two components?
My Hanes manual seems to imply that I remove first, then compress to separate.
Ironliftr3 is offline   Reply With Quote
Old 3 Weeks Ago   #18 (permalink)
gearbox
Super Moderator
it comes out as one piece, then once you have the spring/strut combo off the car, you use the spring compressor to get the springs off. altho, when some friends did mine, they didnt even need one cause the oem shocks were so tired. the rears did not pop open at all, the fronts popped maybe a foot lol.
__________________
www.lubecontrol.com
Member 1025782
Old 2 Weeks Ago   #19 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
I laid mine on the ground, stood on the spring, then opened the top with a ratchet until it popped off. I spent 15 minutes looking for the nut all over the parkade until I realized it was still inside the socket in my hand. So you don't need a spring compressor but it's a little safer. You can rent them for free from a parts shop.
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline   Reply With Quote
Old 2 Weeks Ago   #20 (permalink)
Ironliftr3
New Member
lol...sounds like fun! And the auto parts store 5 minutes from my house does loan spring compressors. No offense to your process, but I think I'll take that route instead!
Tags
2002 , car , civic , factory , forum , height , honda , kit , lean , lower , lowering , restore , ride , shock , suspension
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
cut springs
Rear Sway Bar
removing front sway bar? pros/cons
Rear Sway Bars
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
lowering springs
Kyb or Tokico????
air bag suspension rec's
lowered car leaning to the left!!! plz help
Site Supporters
aluminum radiator
Honda car spoilers
