Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-11-2009   #1 (permalink)
93 civic eg
New Member
93 civic eg is an unknown quantity at this point
93 civic rear suspension squeak
I have a 93 civic , and i just recently replaced my rear shocks because i thought that the right rear was blown because it was squeaking really bad. I bought a complete set front and rear of kyb gr2 for the car. I replaced only the rears. After I installed the rears and drove on them within like 30 mins my right rear was squeakin again. I have kyb gr2 with tenzo typer r springs and jdm lcas. People tell me that it could be my trailing arm bushing but when i hear it when im out the car ( i get someone to push / sit on my hatch ) it doesnt come from that area. It comes from really close to the actual shock. COuld it be any bushings. I dont wanna waste my money on something that isnt wrong. Can somone help me. Or should I just replace my lca bushings. And my top hat bushing. Thanks ahead of time for any help. To remove this ad, register today for free or log in if already registered!
93 civic eg is offline   Reply With Quote
Sponsored Links
Old 10-11-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: 93 civic rear suspension squeak
could also be rear sway bar bushings need lube. usually squeaking is bushing related.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 10-11-2009   #3 (permalink)
YSIDRAG
Senior Member
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Like he said above or like you said the tophat bushings. Do you still have the rubber seal that the spring sits on in the cup of the strut? could also be that if you no longer have that in there. That acts as an insullator{*sp} between the to.
Jay
Fabricated Performance
__________________
www.myspace.com/fabricated_preformance
check out some of my work and cars here.
<---This one tucks 20"s
I have an 01 and an 02
YSIDRAG is offline   Reply With Quote
Old 10-11-2009   #4 (permalink)
93 civic eg
New Member
I still have the rubber ring for the top of the spring. I lubed basically everything place in the rear that has a bushing. It lowered the amount of squeakin that my car makes but still squeaks just a lil bit. But alot better. Maybe ill just replace my lca bushings with some polyurethane ones. Maybe that will solve it and if not i will be back on here for more help. Mechanics are to over priced. I had a toyota corolla s n they charged me 400 just to tell me my stock radio blew all my fuses and wanted to charge 1000 just to replace all the fuses and replace my radio. I rather have a diy job.. n gain experience . thanks for the help..
Old 10-11-2009   #5 (permalink)
YSIDRAG
Senior Member
YSIDRAG's Avatar
Stock hondas come with the same rubber ring on the bottom side of the spring to. thats the one im talking about. You are talking about a car that is over 15 years old to so it could be anything. Exspecialy when you are altering it. ie; lowering it.
__________________
Old 10-11-2009   #6 (permalink)
gearbox
Super Moderator
poly bushings are ALOT louder than stock rubber, esp in the winter when they harden up.
__________________
www.lubecontrol.com
Member 1025782
Old 10-11-2009   #7 (permalink)
YSIDRAG
Senior Member
YSIDRAG's Avatar
Quote:
This is true...
__________________
Old 10-11-2009   #8 (permalink)
93 civic eg
New Member
Maybe ill just go to honda and order some oem bushings.. but will they fit on aftermarket jdm lcas. But im gonna replace all the bushings on the rear anyways i think they are way past overdue. 16 years and i think they are the stock ones. So time for upgrades. lol
Old 10-11-2009   #9 (permalink)
YSIDRAG
Senior Member
YSIDRAG's Avatar
Quote:
yea should be the same bushings
__________________
Tags
89 , 95 , bad , bars , bushings , bushins , civic , hat , honda , shocks , spring , squeak , squeaking , suspension , top
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
cut springs
Rear Sway Bar
removing front sway bar? pros/cons
Rear Sway Bars
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
lowering springs
Kyb or Tokico????
air bag suspension rec's
lowered car leaning to the left!!! plz help
Site Supporters
aluminum radiator
Honda car spoilers
