Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-30-2009   #1 (permalink)
thooten
New Member
thooten is an unknown quantity at this point
Shocks Bottoming Out w/Coil Spring Spacer
OK, so I know I'm probably gonna catch some flak for this, but here's the story:
I bought a lowered 2000 Honda Civic Ex. I don't know how much it is lowered or what equipment was used, other than that the coil springs are yellow. The dude was running 18" rims on it for some reason, and I got some 16" rims to replace them. Today I bought some 205/45/16 tires to put on them, and had them mounted at the shop. The rear wheels were rubbing, so the guy told me to put in some 1" twist-in coil spring spacers to get clearance. I bought them, and he put them in. Now the rear shocks are bottoming out with some frequency, and a squeaking has developed. I don't think the shocks are blown (yet).
Is there any way fix this that will not cost me a lot of money that I don't have? Would replacing the metal twist-in spacers with a rubber ring-shaped spacer help? Is there a shock extender or spacer that would help? Or do I basically just need to totally replace the coil springs and/or shocks?
thooten is offline   Reply With Quote
Sponsored Links
Old 09-30-2009   #2 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
Re: Shocks Bottoming Out w/Coil Spring Spacer
Given the spacer, its unlikely that you are bottoming out. you may be "topping" out the damper rather as in you are running out of droop travel rather then bump travel.
Alternately you may be experiencing coil bind...
anyway, the best fix is to replace the springs with something that doesn't require a spacer for clearance.
Alternately you could buy a camber kit and set the car up with the necessary clearance.
its tough to diagnose such issues with out being there.
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline   Reply With Quote
Old 09-30-2009   #3 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
__________________
Las Vegas SCCA
Randy Pobst
Old 09-30-2009   #4 (permalink)
thooten
New Member
Is it going to damage my current suspension to keep riding like this? Basically, I am very short on money at the moment, and if I can wait till I can afford some coilovers or something I would prefer that.
Also, relating to the squeaking noise, I can reproduce it by bouncing the rear of my car while it is parked. Does that give any clues? It seems to be getting milder since last night... could it be the springs themselves reacting to the spacers?
I appreciate the help. Like I said, I bought the car the way it is, and I'm very ignorant about modding of any kind. Basically I just want my car to work.
Old 10-01-2009   #5 (permalink)
thooten
New Member
Problem solved. Wrong size spacers, they were too long.
Old 10-07-2009   #6 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
makes sense, probably were topping out the dampers.
__________________
Las Vegas SCCA
Randy Pobst
Tags
bottom , bottoming , car , coil , cons , honda , long , pros , put , rear , shocks , spacer , spacers , spring , springs , struts
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
cut springs
Rear Sway Bar
removing front sway bar? pros/cons
Rear Sway Bars
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
lowering springs
Kyb or Tokico????
air bag suspension rec's
lowered car leaning to the left!!! plz help
Site Supporters
aluminum radiator
Honda car spoilers
