Honda Civic SuspensionHonda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
i just bought an 06 si and when i finally got it on the highway at speed i noticed it seemed unstable. it requires constant adjustment to the steering wheel. its bone stock and has 80k on it but im wondering if this is just an alignment issue that can be fixed easily? anybody got a solution?
Sponsored Links
newer civics usually have severe camber issues from the factory. you may have to end up installing aftermarket camber kit to be able to align it properly. do your rear wheels look straight like this | or are they slanted a bit like this \
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
Mine is a 02 EX, and Skunk2 at the rears - no more camber issues anymore even with the 0.75" drop Eibach springs anymore.
The guy with issues is the 06 Si. Iwas just telling him about the life
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
After driving the car for a week being the autophile that I am im going to point out all the questionable things the car does and hope for some feedback. To answer gearbox' question, yes the rears look a little cambered but not extreme. The car was a one owner so I have no idea what may have been done to it in the past. The exhaust is stock and complete, but there is some soot on the tip like at one point it didnt have a cat. Also the clutch seems fishy to me. When I up shift from 1st to second to third it is very jumpy kind of like when a semi truck takes off. When Im coasting in any gear at a steady speed then let off the gas and foot off the clutch(coasting on motor) it coasts for a few feet then kicks down all jerky and shit. like someone tapped the brakes lightly. I figure its either a worn out clutch or something aftermarket. the clutch doesnt seem to slip though, it just engages hard and isnt a smooth transition between gears. the clutch does shift well though when im really on the throttle and shifting quick. thats the only time it shifts smooth. ????????? other than that I look forward to getting in it every day, its a fun ride.
06+ SI has horrible clutch and shifting problems. theres a huge thread here about it and its a known issue by honda. you may still be able to get it fixed if you have warranty, otherwise try calling corporate and they may do a goodwill repair.
__________________
Member 1025782
__________________
Member 1025782
