Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-14-2009   #1 (permalink)
sdaidoji
New Member
sdaidoji is an unknown quantity at this point
Send a message via Yahoo to sdaidoji
Rear arm pivot nut came loose - suggestions to take it out
Nut weld came loose and can't get the bolt out...
There's no space for vise because of the strange metal around it (why is it there anyway?)
Was thinking on welding it back using a spot weld. Can't even cut it out because of a (Eibach?) brace does not give clearance for a saw and heating the nut did not help much...
Love Honda engineers, but sometimes I feel like killing some of them...
sdaidoji is offline   Reply With Quote
Sponsored Links
Old 06-14-2009   #2 (permalink)
silver25civic
Member
silver25civic's Avatar
silver25civic is an unknown quantity at this point
Re: Rear arm pivot nut came loose - suggestions to take it out
did you post some pics of it? if so they didnt show up.
silver25civic is offline   Reply With Quote
Old 06-14-2009   #3 (permalink)
silver25civic
Member
did you strip the nut trying to take it off?
Old 06-14-2009   #4 (permalink)
sdaidoji
New Member
edited just now. see the vise grip marks in the nut (they should have used a Hex nut welded there... hate them right now.
Old 06-14-2009   #5 (permalink)
silver25civic
Member
try using some needle nose vise grips they are alot thinner than regular vice grips.
Old 06-14-2009   #6 (permalink)
sdaidoji
New Member
Quote:
No, the nut is supposed to be welded in there, circled by these strange stuff. It does not have a HEX, it's simply a smooth round nut with threads... Hate, hate, hate honda engineers!
I was supposed to be on the AutoX today...
Old 06-14-2009   #7 (permalink)
sdaidoji
New Member
Yeah, they were the ones that left the marks. sniff.
I might ask my friend to lend his pitbull, but i don't think the head will fit in this tight space...
Old 06-14-2009   #8 (permalink)
silver25civic
Member
the top ones or bottom ones?the top are regular vise grips and bottoms are needle nose vise grips.
ID:	76698   Click image for larger version
Old 06-14-2009   #9 (permalink)
sdaidoji
New Member
Oh, well, will try to fight some more and come back later to give results or else for more options... At least for now, I could force the bolt back to tighten, so it can run for now.
Old 06-14-2009   #10 (permalink)
sdaidoji
New Member
Tried both, actually. both will be straight in the direction of the bolt, so can't get torque enough to take the bolt off (last portion might be stripped...)
Ah, tried using an electrical impact wrench (which helped me tighten back the suspension wile I think what to do), but could not take it out becuase vise will come loose.
Old 06-14-2009   #11 (permalink)
sdaidoji
New Member
BTW, silver25civic, if you area a Honda suspension engineer, don't mind what i said! But if you really are, please use a hex nut welded there!
That way, even if it cames loose, I can still use a normal wrench!
Old 06-14-2009   #12 (permalink)
sdaidoji
New Member
nothing like a bigger vise - found a bigger neddle type and was able to take it out. Nut have 3 protruded parts under the nut which fits on similar slots in the suspension (welds?). Anyway, time for a spin and count the number of bolts that will fall in the way.
Thanks for the help silver25civic
Old 06-15-2009   #13 (permalink)
sdaidoji
New Member
See the lovely fella here
But now all is well, after the new vise grip
Car drives well beyond the limits before, way less understeer. Need to recalibrate rear and front shocks now.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
cut springs
Rear Sway Bar
removing front sway bar? pros/cons
Rear Sway Bars
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
lowering springs
Kyb or Tokico????
air bag suspension rec's
lowered car leaning to the left!!! plz help
Site Supporters
aluminum radiator
Honda car spoilers
