Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-04-2008   #1 (permalink)
HondaKorn
Life is better with 5lug
HondaKorn's Avatar
HondaKorn is a name known to all HondaKorn is a name known to all HondaKorn is a name known to all HondaKorn is a name known to all HondaKorn is a name known to all HondaKorn is a name known to all HondaKorn is a name known to all HondaKorn is a name known to all HondaKorn is a name known to all
Send a message via AIM to HondaKorn
Exclamation car undrivable....
when camber is set like this and something grinds, im assuming its the tire hitting the struts?? also steering is shitty as well, very undrivable. in was playing around with the settings for my new wheels 17x8.5 +30f.....logical explanation???? To remove this ad, register today for free or log in if already registered!
__________________
HONDAKORN FIXED HIS OWN IPHONE SCREEN
For all your rape harness needs....myspace/negrocity
ARC BALLIN'
How is ur honda diff from the rest???
HondaKorn is offline   Reply With Quote
Sponsored Links
Old 07-09-2008   #2 (permalink)
Eyger
A long winded 7th genr
Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned
Send a message via AIM to Eyger
Re: car undrivable....
Um, I'm not an expert, but I think you can only fit a 7.5 wide wheel maximum under there. It also sounds like your offset is too low. Again, I'm not sure, but everything I've seen for the 7th gen is 7.5 width and then like +36 or 38 offset.
Eyger is offline   Reply With Quote
Old 07-09-2008   #3 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Wow, I know the pillowball moves, as mine does on my megans, but it looks like its way in to towards the center of the car. Why is that?
TRIZ is online now   Reply With Quote
Old 07-09-2008   #4 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
what the...
__________________
02BLKCIVIC is offline   Reply With Quote
Old 07-09-2008   #5 (permalink)
tuningmycivic
Ultimate Member
tuningmycivic's Avatar
tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all
Send a message via AIM to tuningmycivic Send a message via Yahoo to tuningmycivic
looks like you dialed in a bit too much camber there bro. i would imagine every tire rotation is chewing up the inner surface of your rims and possibly the tires, depending on where it's rubbing. i would be willing to bet it's either the lower spring perch or god forbid your outer tie rod end where the steering arm connects to it. better jack it up asap and take a look.
not to mention that is a really low offset for such wide wheels. i would consider raising the car a bit as well, since you have full coilovers and adjustable pillowball mounts. have fun
__________________
T.E.A.R.S. Member #5 All turbo builds end in T.E.A.R.S
My turbo build thread 169.39 WHP/157.15 WTQ
Quote:
Originally Posted by TRIZ View Post
you cant just add a k20 to a car like an extra plastic brick to your lego people house.
“Great pain is, as the teacher of great suspicion, the ultimate liberator of the spirit.” - Friedrich Nietzsche as quoted by Mark Twight of Gym Jones
tuningmycivic is offline   Reply With Quote
Old 07-30-2008   #6 (permalink)
trev0006
The Video Collector
trev0006 is a name known to all trev0006 is a name known to all trev0006 is a name known to all trev0006 is a name known to all trev0006 is a name known to all trev0006 is a name known to all trev0006 is a name known to all trev0006 is a name known to all
too wide of a tire
__________________
Honda and other cars video collection
trev0006 is offline   Reply With Quote
Old 07-31-2008   #7 (permalink)
HondaKorn
HondaKorn's Avatar
i fixed it, rim width was fine and tire size was 215/45.....i just went and got it done by a professional
__________________
ARC BALLIN'
Old 07-31-2008   #8 (permalink)
emjay
Super Member
emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough
^^^^ sumting u shoulda done from the start .. u don't align ur own car lol
__________________
boosted 1.7eL -- whp: classified
emjay is offline   Reply With Quote
Old 07-31-2008   #9 (permalink)
HondaKorn
HondaKorn's Avatar
now i know hahahaha
__________________
ARC BALLIN'
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
cut springs
Rear Sway Bar
removing front sway bar? pros/cons
Rear Sway Bars
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
lowering springs
Kyb or Tokico????
air bag suspension rec's
lowered car leaning to the left!!! plz help
Site Supporters
aluminum radiator
Honda car spoilers
