Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Reload this Page
Why are the OEM susupension parts all different costs per trim?
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
LinkBack Thread Tools
Old 06-19-2008   #1 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questioned
EX 4door appears to be $200 per assembly, HX 2 door appears to be <$100 per assembly for the rears. Doesn't this seem odd?
My reference is Majestic Honda, I'm looking to replace my OEM suspension with new parts as inexpensively as possible (current dampers leak).
I've heard that the 4 door suspension is designed to handle more weight than the 2 door (I own a 2-door), so I started comparing part numbers. The assemblies match in all parts minus the springs and dampers. Cool. Assuming they are the same length for physical compatibility, I should be good to go, right?
Except the assemblies have RADICALLY different part costs, and in the case of the LX drawing, there are THREE assemblies associated with the one drawing number, from $85 to $109. The EX 4 door has two, $91 and $200, and the HX 2 door has one at $88.
Why so many different parts? Is anyone else able to tell the difference? I am looking at majestic honda parts, 2001 civic, component "rear shock absorber"
Thanks,
Steve
WhiteRabbit is offline   Reply With Quote
Sponsored Links
Old 06-20-2008   #2 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to behold
Re: Why are the OEM susupension parts all different costs per trim?
I dunno, but the EX has ABS, which really isn't connected to the shock. Just get the cheapest ones.
robbclark1 is offline   Reply With Quote
Old 06-20-2008   #3 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to behold
the LX, DX and HX all use the same strut without the ABS bracket. The EX has its own.... its all in volume of manufacturing.
Boilermaker1 is offline   Reply With Quote
Old 06-20-2008   #4 (permalink)
Unevolved
Rough, Tough, Real Stuff.
Unevolved's Avatar
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
The only suspension difference in the rear I can think of is that the EX has a sway bar in the back, whereas the LX doesn't. But that shouldn't affect the springs and dampers...
Unevolved is offline   Reply With Quote
Old 06-20-2008   #5 (permalink)
robbclark1
robbclark1's Avatar
Quote:
He is specifically talking about the rears. There is no ABS bracket on the rear shock.
Old 06-22-2008   #6 (permalink)
WhiteRabbit
Ultimate Member
what about the strut and spring themselves. I heard the 4 door is stiffer than the 2 door so as to hold up the weight of the rear doors. Any truth to this? I'm considering replacing the struts and springs with sedan suspension because of associated subwoofer and battery weight.
Anyone know?
Thanks by the way for the info on the brackets on the EX parts.
Old 06-22-2008   #7 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
sedans teld to sag alot in the back while coupe doesnt. im not sure if its a problem with suspension or just too much weight. cause i have nothing in my trunk and aftermarket shocks/springs and my rear sags slightly (1/2 finger) when i fill up the gas tank. on stock shocks, it was slammed in the back (no gap). this is without spare tire either. i think the stock shocks are very weak in the back, we did not even need a spring compressor, it just came apart without any tension lol.
gearbox is online now   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
Rear Sway Bars
Rear Sway Bar
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
cut springs
higher after lowering
lowering springs
eibach or tein????
Kyb or Tokico????
did anyone here roll their quarter panels?
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
