Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-24-2008   #1 (permalink)
Oppjonez
New Member
Oppjonez is an unknown quantity at this point
Help put in new struts now a big problem
So I put in my new struts. I did have some problems with putting the front passengers side back in place. I turned the car on ( Low power warning) while still on the jacks and the wheels started turning while in neutral. A long with a weird sound I turned it off right away and put it in park. once in park the wheels would spin with my hands pushing them. I thought in park the front wheels should not move. What should I do?
Please help!!
Sorry for being a newbie
Oppjonez is offline   Reply With Quote
Sponsored Links
Old 05-24-2008   #2 (permalink)
Unevolved
Rough, Tough, Real Stuff.
Unevolved's Avatar
Unevolved is a splendid one to behold Unevolved is a splendid one to behold Unevolved is a splendid one to behold Unevolved is a splendid one to behold Unevolved is a splendid one to behold Unevolved is a splendid one to behold Unevolved is a splendid one to behold Unevolved is a splendid one to behold Unevolved is a splendid one to behold Unevolved is a splendid one to behold
Send a message via AIM to Unevolved
Re: Help put in new struts now a big problem
So you've got an automatic. What year Civic are we talking about here. If you put the car into gear, would the wheels move then?
Could be an axle issue, I'm trying to think of what all you could have messed up by replacing the struts.
We might be of more help if you give some more specific information.
__________________
Unevolved is offline   Reply With Quote
Old 05-24-2008   #3 (permalink)
Oppjonez
New Member
It is a 01 Civic LX.
Lol The sound was I just had the strut bar laying on the towers not connected and it was causing a vibration.
I did just find a washer for the rears.
I do feel like I did something wrong. I just need to figure what. I will try driving it some more to see.
Old 05-24-2008   #4 (permalink)
Oppjonez
New Member
Took the strut off put on the washer. Now I have some kind of ticking coming from what sounds to be the rear-end. I have checked both struts in the rear. Which is a pia because one of the rear upper mounts has no index mark on the top. I had my neighbor drive it back and forth to try and tell where the poping was coming from but over the intake and the fact that he kept spraying me with the washers thinking it was a shifter. I could not find the sound. I guess I can check the front in the morning. I hate it when my car is not running right.
Any suggestions PLEASE
Thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
cut springs
removing front sway bar? pros/cons
Rear Sway Bar
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
Rear Sway Bars
lowering springs
Kyb or Tokico????
Cut Bump Stops?
air bag suspension rec's
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
