Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Reload this Page
Suspension Problem
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Closed Thread
LinkBack Thread Tools
Old 04-12-2008   #1 (permalink)
Honda05
Super Member
Honda05 has a spectacular aura aboutHonda05 has a spectacular aura aboutHonda05 has a spectacular aura about
Suspension Problem
Ok for some reason on the rear passenger side whenever i hit a pretty good dip of some sort or i have more than one person in my car and i turn left just that one side rubs against the rear panal or whatever you wanna call it..Just on the rear right..No problems in the front or anything.The rear left doesnt even do it. I thought maybe the springs were messed up so i bought a new set and it still did it so i bought new struts and it still did it..Then i bought new control arms and it still does it..Anybody have any ideas on what could be the problem..
Honda05 is offline
Sponsored Links
Old 04-12-2008   #2 (permalink)
crazyasian
Diamond Member
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
Re: Suspension Problem
u have too many fat friends. thats your problem!
hahah...j/k
are u bottoming out on that side or just rubbing? cause if its bottoming out sounds like u need or forgot to put in bump stops.
are the struts and springs stock? if they werent i would ask about ride height and dampening setting.
tire might b inflated too much or mounted wrong, could b possibilites but if it was mounted wrong u would feel alot more than rubbing.
another question is how long has it been doin it and wat changes have u done to that side like new tires/rims(not wat u have done by replacing).
crazyasian is offline
Old 04-12-2008   #3 (permalink)
Honda05
Super Member
It never used to do that until i hit a big dip driven to ornaldo..It doesnt rub all the time.Just when when i hit a dip it hits rear panal..I have Tein S-tech lowering Springs, Tokico Struts, SPC Control Arms, Megan Cambers
Honda05 is offline
Old 04-12-2008   #4 (permalink)
crazyasian
Diamond Member
crazyasian's Avatar
you might possibly have that side a bit too low or low enough to have it rub. idk if tokicos have a dappening setting but if it does check that out.
it really just sounds like your shocks are compressing down too much
Old 04-12-2008   #5 (permalink)
Honda05
Super Member
Its not that low at all..The rear is only lowered 1.3inch..My left side is lower than my right and that side doesnt even rub
Honda05 is offline
Old 04-21-2008   #6 (permalink)
civicsrcool
Super Member
civicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questioned
maybe the body roll is makin the tire hit the panel. roll it with a bat and a hammer lol. (the fender lining lip)
civicsrcool is offline
Old 04-21-2008   #7 (permalink)
Honda05
Super Member
I dont think thats the problem..Then the other side should be doing the same thing.. I think the strut is just bad..I can get a new one for under 100 bucks so..Im gonna try that and see if it works
Honda05 is offline
Old 04-29-2008   #8 (permalink)
speedricerx
Diamond Member
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
bump! im having the same exact problem with the same spring/strut combo.. did u fix it yet?
speedricerx is offline
Old 06-19-2008   #9 (permalink)
Honda05
Super Member
Sorry it took me so long to respond back but yes i fixed it..I have to readjust the camber
Honda05 is offline
Old 06-19-2008   #10 (permalink)
speedricerx
Diamond Member
how much neg camber u running now?
Old 06-19-2008   #11 (permalink)
Honda05
Super Member
That i have no idea cause i had my work done over at honda.. I have a guy over who does side work for me..But um what he did was he made the cmaber go in as far as it would go and just readjusted it from there and i havent had any problems since then
Honda05 is offline
Old 07-16-2008   #12 (permalink)
keepItJDM
New Member
keepItJDM's Avatar
keepItJDM is an unknown quantity at this point
i would try replacing the strut should be the fix
keepItJDM is offline
Old 07-16-2008   #13 (permalink)
Honda05
Super Member
close thread. Problem has been fixed for awhile now
Honda05 is offline
Old 08-27-2008   #14 (permalink)
gordongreg
New Member
gordongreg is an unknown quantity at this point
If any of these conditions happens, it is probably advisable to stop the engine ASAP and try to find the cause before the system decides to go into "hard fault" mode.
Louisiana Alcohol Addiction Treatment
gordongreg is offline
Closed Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
Rear Sway Bars
Rear Sway Bar
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
cut springs
higher after lowering
lowering springs
eibach or tein????
Kyb or Tokico????
did anyone here roll their quarter panels?
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
