Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Reload this Page
slamming a 7thgen
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
LinkBack Thread Tools
Old 02-05-2008   #1 (permalink)
ultimatetuner10
Technical Assistant
ultimatetuner10's Avatar
ultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questioned
slamming a 7thgen
post a pic of your slammed 7thgen and what suspension you are using I am interested in putting this thing on the ground
ultimatetuner10 is offline   Reply With Quote
Sponsored Links
Old 02-05-2008   #2 (permalink)
civicsrcool
Super Member
civicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questionedcivicsrcool should not be questioned
Re: slamming a 7thgen
m running koni yellows ground control combo. its slammed all the way down. heres some pics.. im running 205/50/16
http://img100.imageshack.us/my.php?i...475c381zz5.jpg
http://img82.imageshack.us/my.php?im...5b32c4drr1.jpg
http://img149.imageshack.us/my.php?i...db0f31ear8.jpg
http://img227.imageshack.us/my.php?i...b889b63gf2.jpg
hope this helps.. let me know if you need anymore help or pics or whatever.
EDIT: dudeee you got the same car and color as me.. sickkk. lol
civicsrcool is offline   Reply With Quote
Old 02-05-2008   #3 (permalink)
ultimatetuner10
Technical Assistant
^^think ground controls will work with tokico HPs?? I can still use my old camber equiptment right..i actually wana be quite a bit lower than that, I am on 185 65 14 steelies, and I can roll fenders if needed
Old 02-05-2008   #4 (permalink)
ultimatetuner10
Technical Assistant
This is her now on Tokico HP, Neuspeed sport, SPC camber kit and zeroed out all around
what about some neuspeed race springs...anything more low out there??
Old 02-05-2008   #5 (permalink)
Envy
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
ground controls WILL work with HP's. You just have to make srue you buy the right set for the right shocks. There is a HP set out there.
Envy is offline   Reply With Quote
Old 02-05-2008   #6 (permalink)
ultimatetuner10
Technical Assistant
Right..how low can I go though..I wana be tucking a bit of tire all around, but still a fairly tire friendly alignment
Old 02-06-2008   #7 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questioned
STOP, TUCK, and ROLL!
Alpha 5 is offline   Reply With Quote
Old 02-06-2008   #8 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
do u have a dent in ur left rear door?? and i think there are some 3" lowering springs out there, and i think progress are 2.25" drop
greeen01civic4d is offline   Reply With Quote
Old 02-06-2008   #9 (permalink)
mugenman
"mmmBAHHHH" - vtec y0
mugenman's Avatar
mugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questionedmugenman should not be questioned
not as slammed as other hondas but its dumped a lil over 3 1/2 inches over stock
mugenman is offline   Reply With Quote
Old 02-06-2008   #10 (permalink)
ArrizX
New Member
ArrizX's Avatar
ArrizX is an unknown quantity at this point
Not to the ground, but so low it makes it EXTREMELY hard to be a DD where I live.
Since this was taken, the rear wiper has been shaved.
Pretty low considering if you notice where I live in the sticks.
Edit-
Actually, if I remember right i'm only 4'' off the ground.
Anyways, to give you an idea of how much it sometimes sucks, at school when I was in auto shop, I wasnt even able to drive my car on the lift for an oil change.
And I had to drive it on boards to be able to fit a jack under it.
ArrizX is offline   Reply With Quote
Old 02-06-2008   #11 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to behold
Why not get air suspension? best of both worlds
TRIZ is offline   Reply With Quote
Old 02-06-2008   #12 (permalink)
mugenman
mugenman's Avatar
ever ridden or driven a car with air ride triz? not exactly a likely canidate for a comfy daily
Old 02-06-2008   #13 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to behold
Quote:
that and you have no way to regulate tire wear.
robbclark1 is offline   Reply With Quote
Old 02-06-2008   #14 (permalink)
ultimatetuner10
Technical Assistant
Sorry guys all those arent quite low enough
somethin like that maybe
Old 02-06-2008   #15 (permalink)
Ballatician
Senior Member
Ballatician has a spectacular aura aboutBallatician has a spectacular aura about
**These are not my cars but they give you an idea of what slammed 7th gen will look like**
Ballatician is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
Rear Sway Bars
Rear Sway Bar
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
cut springs
higher after lowering
lowering springs
eibach or tein????
Kyb or Tokico????
did anyone here roll their quarter panels?
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
