Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-17-2007   #1 (permalink)
hondrarr
New Member
hondrarr is an unknown quantity at this point
Ball Joints
Hi, My wife owns a 7th Generation Civic Sport.
At 50k miles it required new balls joints but because honda do not sell these separately the full arms needed replacing costing a shit load of $$$. £350.
This isn't what i expect of a honda....I bought it because i thought it would be reliable and the parts , although being more expensive would last longer.
Has anyone else had this problem? I read that it could be because she is running 205/40/17R tire/wheels. The Originals were 195/65/15R. Someone mentioned that the bigger wheels stress the suspension more.
Another guy suggested replacing the wheels with the originals (costly as i'll probably lose money as the current wheels have good rubber on.)
Another guy suggested buying lower springs, as this would reduce ride movement, does this make sense?
What are everyones thoughts??
I'm no mechanic so i won't pretend to know all
hondrarr is offline   Reply With Quote
Sponsored Links
Old 04-17-2007   #2 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
Re: Ball Joints
You can aftermarket ones (i.e. generic, non-Honda stuff) but I don't know how to change them. PM skipbarber about what parts to get.
It has nothing to do with the wheels and don't lower the car if she doesn't want it. Lowering the car will add more stress to the ball joints.
Ball joints go on every car. Honda is known for reliability in engines, but wearable parts are wearable parts.
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 04-17-2007   #3 (permalink)
Stratablak314
Member
Stratablak314's Avatar
Stratablak314 is an unknown quantity at this point
Send a message via AIM to Stratablak314
Re: Ball Joints
I'd recommend going back to 15s. The bigger wheels probably didn't add to the ball joint stress, but if you're not goin to drop it on your 17s then just stick to the stock setup. 40 series tires are pretty rough on our cars. That might be a little harsher on your struts than cushy 55s or whatever come on the 15s. Its less rubber absorbing the bumps and more of your wheel jolting up your strut. I'm lowered on 17s with 215/45 and i've had no supsension troubles, but I have aftermarket struts. Maybe those will help after the new joints are replaced. But believe me, if you think the stock suspension is boucy wait til you lower it a bit.
Stratablak314 is offline   Reply With Quote
Old 04-18-2007   #4 (permalink)
hondrarr
New Member
Re: Ball Joints
Quote:
So you'd recommend that if she sticks with 17's that she drops it?
You said the ride would be a lot bouncier once lowered - would replacing the springs with different ones resolve this? if so can you or anyone recommend a good brand, nothing top of the line but something good to do the job as it isn't a ferrari
I assume there are no performance/aftermarket parts that replace the oem honda ball joints?
I don't know if the civic sport has a firmer suspension but it does feel pretty bumpy even on normal roads. When you wheel spin in the car (something i generally try to avoid, being a bit lame and bad for ones car) it hops quite a bit, is this because of a firm suspension or a soft suspension? or because the tires are real grippy(being wide)? It doesn't drop any smoke but it hops like the hulk is doing fast bench presses with the car.
Old 04-18-2007   #5 (permalink)
hondrarr
New Member
Re: Ball Joints
I'll send him a PM. thanks!
I suppose you're right, We bought the car because of the reliability in the engine/gearbox department. Previously had a VW that the gearbox went on, only 5 years old and less than 50k. Disappointing as well as dangerous, wouldn't like a box full of chewed up cogs while hitting 90mph.
The drive and ride in the sport/type r/s line are supreme, i prefer over the focus and that's saying a lot as the focus handling is great.
Old 04-24-2007   #6 (permalink)
Stratablak314
Member
Re: Ball Joints
To lower the car you'd have to replace the oem springs with an aftermarket brand ($150-250), Or by a coil over system ($1000 +). Then to prevent your oem struts/shocks from going bad with your replacement springs, you'll need aftermarket shocks ($350-500). Then after your new spring/shock set up or coilovers your car will look better (assuming you pick a spring with the amount of lowering you want) and be more responsive but will ride pretty stiff and bouncy. There's tons of info on here about all of that.
As far as the ball joints, like robbclark said, they have several different replacement brands, but i wouldn't know how to go about replacing it. Call NAPA or Autozone. haha
Oh yea.. the hopping when you spin your tires is because the car is front wheel drive. You don't feel that in a rear wheel drive car.
Tags
ball , joint
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
cut springs
Rear Sway Bar
removing front sway bar? pros/cons
Rear Sway Bars
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
lowering springs
Kyb or Tokico????
air bag suspension rec's
lowered car leaning to the left!!! plz help
Site Supporters
aluminum radiator
Honda car spoilers
