Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-18-2007   #1 (permalink)
realitycheck
Super Member
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Need some camber help!!!!
Alright guys I have an 02 Ex I put eibach sportlines on it, with a camber kit. The camber kit I have isnt enough now to pull it back out to 0 on the front. What have you guys done once the bolt thing on the front ran out of adjustment??? Thanks To remove this ad, register today for free or log in if already registered!
__________________
A realitycheck is a time in your life where you do a check of your heart. A time you check where your relationship with God is and where it’s going. Then you make a decision as to where your going from here.
So many Struggles, So many Trials, So many reasons for me to Fall, But I have all Strength, And I have all Power, And I will Bury You!
realitycheck is offline   Reply With Quote
Sponsored Links
Old 01-18-2007   #2 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
Sounds like you have the car lowered a whole hell of a lot. Dut dont worry about it, as the OEM spec allows for -.75 deg camber on the nose. 0 Deg is horrible for every thing but drag racing...
You may want to read this...
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline   Reply With Quote
Old 01-18-2007   #3 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
your going to want to rep this guy^
TRIZ is offline   Reply With Quote
Old 01-18-2007   #4 (permalink)
realitycheck
Super Member
Well I just have the eibach sportlines on there which are only supposed to lower 1.4" but they just seem to keep getting lower, I've had them for probably 3 or 4 years now. Anyway last time I get the car aligned they were out of adjustment on the front. So now I really need an adjustment cause the front is wearing my tires out on the inside and I just swapped it to the back which is even worse camber so I need to get it adjusted. But I dont have anymore adjustment on the front. So what can I do?
__________________
Old 01-18-2007   #5 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Thats toe, not camber. Camber doesnt really "eat" tires, its the toe that does it.
Post the specs or scan the sheet from the shop.
On the other hand, if you've had the same tires for 3 years, yes, they'll show camber wear and there isnt much you can do about that other than replace em.
I'd say anything less than -1.5 degrees on the front is fine for daily cruising.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Front camber is still bad even with camber kit Khmi Suspension Performance 11 02-14-2005 05:54 PM
Bad camber with Tein SS and SPC camber kit Vinnie Suspension Performance 8 12-23-2004 11:58 AM
buy camber kit or replace stock camber control arms? thoughthard Suspension Performance 14 10-07-2004 07:41 PM
How do you adjust the front camber without camber plates? Boilermaker1 Suspension Performance 13 02-20-2004 11:58 PM
Computerized Camber Adjustment Results: Is my camber correct? (Pic Included) aZnVoYCe Suspension Performance 16 10-19-2002 01:19 PM
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
cut springs
Rear Sway Bar
removing front sway bar? pros/cons
Rear Sway Bars
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
lowering springs
Kyb or Tokico????
air bag suspension rec's
lowered car leaning to the left!!! plz help
Site Supporters
aluminum radiator
Honda car spoilers
