Go Back   Honda Civic Forum > GENERAL > Honda Civic Suspension
Honda Civic Suspension Honda Civic Suspension can do many beneficial things. Some lower the suspension for style while others do it for racing. This is where you can give and take information about the Honda Civic Suspension setup.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-26-2006   #1 (permalink)
LT2004ever
I wil fix vBPlaza today
LT2004ever's Avatar
LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all
Send a message via AIM to LT2004ever
Rear Sway Bars
Hey guys if u had to invest in one which would it be?
RSX type-s 19mm rear sway bar
Progress Rear Sway 20mm i think
Neuspeed Rear Sway dont know the mm
srry i forgot to put it in mem ride talk
__________________
By speedfoos[/url]
R.I.P. 7thgen Club Member #5
Auto Driver by Force Member #2
Riding 4x4 Till Saved For Drop Member #1
"The most wasted of all days is a day without laughter" e.e.cummings
Clover Green 2001 EM2
CHEAP, RELIABLE, FAST - you can only choose two
LT2004ever is offline   Reply With Quote
Sponsored Links
Old 12-26-2006   #2 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned
Send a message via AIM to Alpha 5 Send a message via MSN to Alpha 5 Send a message via Yahoo to Alpha 5
I have been thinking about the progress my self.
Alpha 5 is offline   Reply With Quote
Old 12-26-2006   #3 (permalink)
FALKEN
FALKEN's Avatar
FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light
19mm
FALKEN is offline   Reply With Quote
Old 12-26-2006   #4 (permalink)
J Smith
Senior Member
J Smith is an unknown quantity at this point
Go OEM with the RSX
word to your mother
J Smith is offline   Reply With Quote
Old 12-26-2006   #5 (permalink)
CivicDuty
Member
CivicDuty's Avatar
CivicDuty is an unknown quantity at this point
If all of your suspension components are stock then the 19mm is plenty. It reduces understeer and give the car a more neutral feel.
If your car is an 01-02, then the 19mm rear is a good match with the 25mm front. Honda reduced the size of the front sway bar in the later years so I am not sure how the 19mm or larger would feel on those models.
CivicDuty is offline   Reply With Quote
Old 12-26-2006   #6 (permalink)
slowwhitecivic
Senior Member
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
you guys know where i can purchase a cheap rsx rear sway bar..
slowwhitecivic is offline   Reply With Quote
Old 12-27-2006   #7 (permalink)
phantomninja
Senior Member
phantomninja's Avatar
phantomninja has a little shameless behaviour in the past
go have clubrsx.com a visit those guys sell a lot of their stock ones usually for like 50-80 dollars or so but if you get the 02-04 ones they are 19mm if you get the 05-06 ones they are 21mm and i would go with that if i were you because thats what i have and it's freakin beautiful on the track
phantomninja is offline   Reply With Quote
Old 12-27-2006   #8 (permalink)
LT2004ever
LT2004ever's Avatar
ok, 19mm would be the way to go, thats cool. N e thing i gotta look out for when installin it?
__________________
By speedfoos[/url]
Old 12-27-2006   #9 (permalink)
CivicDuty
Member
CivicDuty's Avatar
Don't forget to buy the mounting bushings and make sure you use a bunch of penetrating oil on the end links. You need to use an allen key in the end of the bolt to hold it while turning the nut. The allen portion usually fills up with rust and strips easily so be careful.
If you try to hold the bolt with vise grips you'll bugger the threads. Either way, don't be suprised if you need new end links before you're done. I did mine early in the car's life and managed to escape unscathed. If you live in a warmer climate (unlike me) you may not have a rust issue, but, still be careful.
Old 12-27-2006   #10 (permalink)
LT2004ever
LT2004ever's Avatar
Would i need the mounting bushings, seing as how i have a EX??? like in the DIY on the site, it says that "install their mounting kit since 2001 LX's didn't come with a rear sway bar from the factory"
__________________
By speedfoos[/url]
Old 12-27-2006   #11 (permalink)
MisterFrankieJ
Super Member
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enough MisterFrankieJ will become famous soon enough
Send a message via AIM to MisterFrankieJ
You just need the 19mm bushings that usually come with the bar. The stock brackets work fine.
__________________
Spending money I don't have, to buy parts I really don't need, to impress people I don't know.
-from ls1tech.com
Official F1 fan club member #5
MisterFrankieJ is offline   Reply With Quote
Old 12-27-2006   #12 (permalink)
LT2004ever
LT2004ever's Avatar
ok like the one i was thinking about was here
things for sale since car is sold
he said something about grey's endlinks, and would that be all i needed from him?
__________________
By speedfoos[/url]
Old 12-27-2006   #13 (permalink)
MisterFrankieJ
Super Member
Just ask if it comes with bushings but it probably will. Grey's endlinks aren't needed but they are an upgrade.
__________________
-from ls1tech.com
Old 12-28-2006   #14 (permalink)
LT2004ever
LT2004ever's Avatar
an upgrade? ok how so? like i tried searchin but no one explains how it all works. Srry man im a new to the whole suspension scene. lol thats y i started this thread, just looking up info.
__________________
By speedfoos[/url]
Old 12-28-2006   #15 (permalink)
CivicDuty
Member
CivicDuty's Avatar
Here's a link to Grey's endlinks. As you can see they are much more beefy than stock....stronger and don't wear out as fast. That's why they are an upgrade.
Since the guy you mention is selling the bar with the endlinks....I would take 'em....especially if you are at all worried about messin' up the stock ones during your install.
http://www.civicforums.com/forums/15...ml#post3510627
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Sway Bars And Rear Strut Bars JDM EM2 North Cali 11 11-04-2004 12:15 AM
RSX Rear Sway bars 19mm Zolutar Honda Civic Parts for Sale 18 08-05-2004 12:05 PM
front and rear sway bars sffree Suspension Performance 34 07-11-2004 12:02 PM
FS: Front and rear sway bars, endlinks, bushings PlasmaGT Honda Civic Parts for Sale 8 06-24-2004 04:12 PM
Someone explain the rear sway bars to me cdmx Suspension Performance 4 02-19-2003 06:45 PM
User Login
Our Partners
used new
Top 10 Threads
Important Suspension Info! Read Now!!!
cut springs
Rear Sway Bar
Rear Sway Bars
removing front sway bar? pros/cons
*updated* Springs Ordered: Which Shocks/Struts *poll up*.
lowering springs
Kyb or Tokico????
air bag suspension rec's
lowered car leaning to the left!!! plz help
Site Supporters
aluminum radiator
Honda car spoilers
