2005 EM2 Fenderwell Trim
Old 12-06-2014
fijiblue05's Avatar
fijiblue05 is an unknown quantity at this point
Well I live in AZ and my awesome Civic is almost 10 years old now!
The adhesive for the fenderwell trim has started to fall apart. I've had to take off the trim on the front 2 fenders.
Have you ever run into this issue?
Do you simply replace the adhesive or do you replace the trim as well?
What adhesive do you use?
Old 01-25-2015
fijiblue05's Avatar
Re: 2005 EM2 Fenderwell Trim
I finally replaced the trim today.
I bought some 3M Auto Super Strength Molding Tape from the auto parts store.
You can basically follow the instructions on the back of the package.
I made sure my car was clean and removed the old adhesive with just my hands to avoid scratching the paint. I didn't use masking tape to mark where the trim used to be because I had pictures instead. I cleaned the adhesive off of the old trim. I then applied the tape to the trim. I used a utility knife to cut the excess adhesive off so that it fit the shape of the trim.
The main advice I would give is to be patient and take your time putting the trim back on to the car to make sure it looks nice.
In the picture, the top trim piece has the adhesive tape applied.
Old 09-03-2015
Pier7866's Avatar
Pier7866 is an unknown quantity at this point
Well that type of fenderwell trim is after market because if you use genuine trim from Honda that is done with ribit and does not require adhesive of double sided tape so your car has the trim on the fender with double sided tape that means its not original from factory. Hope this help.
jtcavey
09-30-2015 02:18 PM
brash99
09-29-2015 08:42 AM
rayman009
09-12-2015 08:30 PM
lolhowell
Photography & Videography
09-11-2015 05:09 PM
h4ldol
09-10-2015 12:25 PM
Quick Reply: 2005 EM2 Fenderwell Trim
