Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Other 7th Gen
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-23-2009   #1 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Dead pedal changes
I have never been keen on the dead pedal in the 7th gens. It is always dirty & hard to clean. The carpet to the left on the side of it could also not be kept clean.
So... I modified my pedal with a smoother cover & also made a rubber flap on the left that goes up under the plastic kick panel trim and covers the carpet.
I cut a hole in the cover where the mounting stud is and used a black plastic cap to fill it in.
The cover material is black vinyl base board trim from the hardware store (it still has the factory molded lip on the left side)
Like it, Hate it I don't care. I have had it in for a while and works great and no further damage to the side carpet.
Name:	Dead Pedal 1.JPG
ID:	75950   Click image for larger version
Name:	Dead Pedal 2.jpg
CraigW is online now   Reply With Quote
Sponsored Links
Old 03-23-2009   #2 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Re: Dead pedal changes
Nice, good job man
TRIZ is offline   Reply With Quote
Old 03-23-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
not bad but maybe paint the strips to match black?
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 03-24-2009   #4 (permalink)
CraigW
Platinum Member
CraigW's Avatar
I later added the aluminum trim to cover the nasty looking glue job to the right side (I did not want the cover to work loose and lift on edge and corner)
I had thought about trying to paint or maybe covering the trim in black grip surface tape. Paint will most likely wear quick in that enviroment and the grip surface tape is just another place for dirt to collect.
It is easy to remove, sort of a work in progress still kicking around ideas on the trim.
Thanks for the replies guys !!
Old 05-14-2009   #5 (permalink)
thenewdiabolic
Member
thenewdiabolic is an unknown quantity at this point
call me stupid, but i cant get whats left of my old dead pedal out. all thats left is the stud type thing on the right (idiot before me somehow broke it out of the car), and i cant get it out. how is it done? thanks and sorry if its overly obvious but i couldnt get it.
thenewdiabolic is offline   Reply With Quote
Old 05-15-2009   #6 (permalink)
gearbox
Super Moderator
i just changed mine with a new one. you need to remove that nut on the bottom and also that plastic clip thing on the top right. i think you need an allen hex wrench and just turn it out like a screw. you could prolly yank it out with enough force too. thats what happened to mine and it was too loose so i had to get a new clip. it presses on but unscrews back out.
__________________
www.lubecontrol.com
Member 1025782
Old 05-15-2009   #7 (permalink)
thenewdiabolic
Member
alright thanks ill give that a shot
Old 05-15-2009   #8 (permalink)
BJanzen
Senior Member
BJanzen's Avatar
BJanzen is a glorious beacon of light BJanzen is a glorious beacon of light BJanzen is a glorious beacon of light BJanzen is a glorious beacon of light BJanzen is a glorious beacon of light
Send a message via MSN to BJanzen
For some reason I dont like the look, maybe if it was all black id like it better, but I get the reason behind it. I ended up just getting a new one.
http://www.strutking.com/civic-39-01...-/prod_17.html
Thats what I did instead.
__________________
All audio...
BJanzen is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
2001 Civic Widebody Kit or Fender Flares
Alpha's ES2 lots of pix. I can't wait to get mounted. post 70
RS Grill/RS Lip Kit
Paint codes for 2001 civic
Show me your engine bay
New German 04-05 EM2 civic widebody kit
*PICS ADDED* Hello! just got a 2001 Inca Pearl Civic Coupe EX
simota carbon charger for 7thcivic
N/A D17A Non-Vtec
Help in Mounting a GPS
Site Supporters
aluminum radiator
Honda car spoilers
