EGR/CVC valve,
Rep Power: 0 EGR/CVC valve,
Acording to the chiltons manual I might have a cvc valve instead of an EGR valve, But the manual doesnt say where its located, Doe any one have a clue?
91 Civic sedan LX with D15B2 engine
Re: EGR/CVC valve,
Sometimes you can look in one of the many dealer level online parts catalogs, find if it was available for (installed on) your car (use the VIN as the filter)
My parts catalog shows the car should have an EGR valve. EDIT: Might have one
I have no idea what your Chitlins manual is calling a CVC valve, or if you misread or mistyped it, if the parts department isn't calling a part the same thing that a service manual is calling it, or if it is some generic reference to a part that may not even be for your car, because that manual is supposed to cover far more than just your particular version of the car....
Do you know what the letters CVC are supposed to stand for, or where it should be located?
(I have a couple guesses but neither match exactly, need more info about it)
PCV? PCS? TWV? XYZ? OMG? LMNOP? Sometimes I hate all the abbreviations they use.
Rep Power: 0 Re: EGR/CVC valve,
CVC stand for constant vacum control,, have no idea where its supposed to be located, but my guess would be on intake manifold,, think they use all these abbreviations to confuse us DYI types LOL
Re: EGR/CVC valve,
Now I'm getting somewhere....Found it in some older factory vacuum diagrams
EGR and CVC are used together on 1.5L automatic trans California emissions car.
The diagram only says "Cal w/AT" so I assume 49 state emissions and manual trans cars would not use them.
Your underhood emissions label should tell what the car is equipped with, is it still there?
No emissions label is missing also,,, but I dont see anything that even resembles an EGR valve,, any Idea where it might be located,, Usually on the intake manifold right?
Re: EGR/CVC valve,
You are not in California, right?
You won't have either item on a 49 state emissions car.
(I edited post #2 days ago)
EGR would be bolted to the intake if it were present.
morkys
10-29-2015 06:16 PM
morkys
10-25-2015 09:29 AM
