1994 civic will not start usually after rainy days?
Rep Power: 0 1994 civic will not start usually after rainy days?
OK MY CIVIC WILL NOT START USUALLY AFTER RAINY DAYS. I HAVE NOTICED THAT MY FUEL PUMP DOES NOT PRIME WHEN THIS HAPPENS. I CHECKED FOR POWER AND HAD NONE, SO I WIRED IT DIRECTLY TO THE BATTERY AND THE FUEL PUMP RAN, BUT THE INJECTORS DIDNT OPEN. THEY OPENED ONCE THE CHECK ENGINE LIGHT TURNED OFF. I HAVE ALREADY REPLACED THE RELAY, AND THE WHOLE IGNITION SWITCH. WHAT CAN BE THE PROBLEM. ONCE I GET THE CAR TO START, IT WILL WORK THE WHOLE DAY WITH NO PROBLEMS????.. HEEEEEELLLPPPPPP
Re: 1994 civic will not start usually after rainy days?
My 89 Honda Crx HF won't start on rainy days-OK when it's not raining. I've changed the relay, still won't start. On dry days it starts fine. How do I go about checking the distributor for being "fried" as the other thread stated.
Received 1,440 Likes
Rep Power: 338 Re: 1994 civic will not start usually after rainy days?
yeh found this thread, congrats. now look in this too.
https://www.civicforums.com/forums/2...its-humid.html
OMFG, did I do something useful in that thread?
When it will run correctly on a dry day, try misting a little water from a spray bottle on the cap and plug wires. When it stumbles you know you hit a problem area. Replace parts as necessary.
If you change out a distributor cap, be sure to replace the rubber seal part #13 here:
Rep Power: 338 Thread
Jonnie.
01-13-2019 11:21 AM
deus-ex
04-13-2015 12:29 PM
