Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #1 (permalink)
lil_wilde
New Member
lil_wilde is an unknown quantity at this point
engine overheating? smoke from manifold area
Recently the temperature guage has been saying that my engine is overheating when Ive only driven a few blocks. Then the guage will drop to normal (about halfway). Its kind of erratic.
I just replaced the radiator so it shouldn't be a broken radiator.
I also noticed that there is smoke coming from the area of the manifold when the engine is running.
I also go through engine oil really quickly.
Could these things be related?
Any ideas what the problem might be?
Thanks!
I have another post regarding the car not accelerating. Perhaps this problem is related to my other problems.
lil_wilde is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #2 (permalink)
tbohar
Senior Member
tbohar's Avatar
tbohar is on a distinguished road
Re: engine overheating? smoke from manifold area
When you changed your rad did you properly bleed the air out of the system?
tbohar is offline   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
lil_wilde
New Member
Yah, I think there must have been air in the radiator. No, I didn't bleed the air out and this morning I managed to pour about a 1/4 of a jug of coolant into it even though I "filled" it up when I put in the new one.
After adding the coolant it isn't overheating.
Thanks for your help.
Old 2 Weeks Ago   #4 (permalink)
tbohar
Senior Member
tbohar's Avatar
There is a procedure on this website for how to properly bleed the air out of your cooling system. It involves the heat being on full blast and such. I highly suggest you follow it, so you don't have any more problems. It's easy to find if you search for it, and its a bit more involved, most people don't do it right until they read up on it.
Old 2 Weeks Ago   #5 (permalink)
lil_wilde
New Member
Greta, thanks!
Tags
2004 , 95 , air , bleed , civic , coming , cooling , coupe , dx , engine , honda , overheat , overheating , smoke , system
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
