Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 4 Weeks Ago   #1 (permalink)
z6coupe
New Member
z6coupe is an unknown quantity at this point
Question 95 d16z6 really bad miss
i have a 95 civic coupe..d16z6 (1.6 vtec) it has developed a REALLY BAD miss..
i have changed plugs, wires, cap and button....checked fuel filter and pump and even checked to see if cat was plugged...nothing seems to help... it doesnt seem to miss at an idle but anything above 2000 rpm is horrible....any ideas...ill try anything!!
z6coupe is offline   Reply With Quote
Sponsored Links
Old 4 Weeks Ago   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: 95 d16z6 really bad miss
what brand parts are you using? alot of times the cheapo parts do not work well, and certain brands of spark plug do not work at all. you should at the least have ngk/denso plugs and ngk wires. check the cylinder compressions too. and check the fuel pressure. your injectors may also be clogged and not spraying fuel properly.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Tags
bad , civic , d16z6 , honda , idle , injectors , miss , misses
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
