Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 4 Weeks Ago   #1 (permalink)
ebadai98
New Member
ebadai98 is an unknown quantity at this point
Car Overheating Need Help Fast!!!!!!!!!!
I am new to this site and to civics but please help me out. I have a 94 civic dx sedan. My A/C never worked in my car. My problem is that my car is overheating. Now i have replaced the thermostat, the fan temp switch/sensor, the cooling fan relay, and i have flushed the old coolant out of the car twice and put new coolant in. When the car is in idle the fan kicks on when the car is getting to hot but for only like 15 seconds then goes off and when i am driving it does the same thing it only stays on for about 15 seconds and goes off. Why wont it stay on to cool the car down? I don't know what else to do and the water pump is working because the top radiator hose is hot and the bottom is cold and when it over heats bubbles up in the recovery tank. So any help or suggestions would be great thanks in advance. To remove this ad, register today for free or log in if already registered!
ebadai98 is offline   Reply With Quote
Sponsored Links
Old 4 Weeks Ago   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Car Overheating Need Help Fast!!!!!!!!!!
15 seconds is the usual cycle. it doesnt stay on forever and usually the fan does very little of the cooling. the bottom hose should not be cold. it should be cooler than the top hose, but it should still get fairly warm, if not hot, depending on outside temps. if it really is cold, you have a clogged radiator and coolant is not circulating thru the engine properly.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Tags
1993 , 2004 , bottom , civic , cold , coolant , coupe , crv , dx , honda , hose , idle , overheat , overheating , overheats , radiator
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
