Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-17-2009   #1 (permalink)
maphucka
New Member
maphucka is an unknown quantity at this point
94 Civic VX...yes..VX..and i need help
hey people im a noob to the site..... i have a 94 civic hatch that is sputtering a lot. it also will not let me accelerate thru 3500 rpms at all. it's like it redlines at 3500 and will not provide any power. im not sure if its the type of engine or a problem internally. it sounds like a exhaust leak but ive checked all that. i got the car from a friend that lives in the high country of AZ and it was sitting there for awhile. ive done all the quick changes(fuel filter, plugs, battery) but ive only had it a week...
any help would be great
thanks
maphucka is offline   Reply With Quote
Sponsored Links
Old 4 Weeks Ago   #2 (permalink)
YSIDRAG
Senior Member
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Re: 94 Civic VX...yes..VX..and i need help
thanks
Could be a few differant things, a clogged cat, timming belt jumped a tooth or you have plug wires on wrong.
Check the firing order on the spark plugs. make sure they are right. 1-3-4-2 is the order.
If thats ok unbolt te exhaust in front of the cat, look to see if it is clogged and run it with it unbolted to see if it runs any bettter. If you say it sounds like it has an exhaust leak it could be it is cloged. The exhaust has to go some where. so it forces it self out where ever it can. Sounds like this is the problem.
If not bolt it back togther check the timming on it. you may need some help from a shop or someone who has done this before if you never have. if it has jumped a tooth or 2 on the belt it will be way under power.
Hope this helps you alil
Jay
Fabricated Performance
__________________
www.myspace.com/fabricated_preformance
check out some of my work and cars here.
<---This one tucks 20"s
I have an 01 and an 02
YSIDRAG is offline   Reply With Quote
Tags
94 , box , cat , civic , engine , exhaust , forum , forums , fuse , honda , jumped , spec , specs , tooth , vx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
