Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-13-2009   #1 (permalink)
chriswf
New Member
chriswf is an unknown quantity at this point
Hey guys, brake lights out. Bulbs and fuse both good. Switch disengages... And what..
I have a 91 civic wagon. Brake lights aren't coming on. The rear night time lights come on... But when I push the pedal I'm not getting a brake light.
ALL fuses are good and intact. Bulbs are good, right size/filament.
When I push the brake in, the switch piece slides out...
BUT, there's a blue and red wire, that connects to that "3M" adapter. Both ends on each side of that 3M adapter are cut. The green wire (that runs from the brake switch) is still intact.
Is the red and blue important? I can't see where either side runs so I'm unsure of what it does...
Any tips on what to trouble shoot next would rock!
Thanks guys.
Edit: Here's that wire btw...
chriswf is offline   Reply With Quote
Sponsored Links
Old 10-14-2009   #2 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: Hey guys, brake lights out. Bulbs and fuse both good. Switch disengages... And wh
The white part ?? It looks like a wire tap to me, used to tie a new wire into an exsisting wire. It was likely someones mod or for an alarm.
Does your horn work ?? They usually share a fuse, If it does work I would start by checking for voltage on the 2 wires going to the switch. 1 side should have constant voltage and the other side should have it when the pedal is pushed down.
CraigW is online now   Reply With Quote
Old 10-14-2009   #3 (permalink)
chriswf
New Member
Found out the fuse under the hood was blown.
Horn still doesn't work. When I push the button everything on the car dims. I assume the horn(s) are bad. Don't know if I care at all about a horn at the moment...
But thanks much for the help!
Tags
2000 , 2002 , 2006 , 95 , blows , brake , button , civic , cost , crv , fuse , honda , horn , light , lights , rear , switch
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
