Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-23-2009   #1 (permalink)
Civic coupe 94
New Member
Civic coupe 94 is an unknown quantity at this point
94 Civic Engine Swap?
Hi, hope someone can help!
I have a 1994 1.5 Civic Coupe and really want to swap the engine for the 2.2 out of a Prelude. Apart from engine/gearbox and loom, what else am I going to need to swap? Like driveshafts, etc?
Thanks guys!
Civic coupe 94 is offline   Reply With Quote
Sponsored Links
Old 09-23-2009   #2 (permalink)
Global Key
New Member
Global Key is an unknown quantity at this point
Re: 94 Civic Engine Swap?
You will need to change the driveshafts, ecu, new engine mounts, probably the rear axel off the prelude as your going to need discs on the back aswell as the front, and maybe the front suspension as the prelude engine will be a lot heavier and than the 1.5
Global Key is offline   Reply With Quote
Old 09-30-2009   #3 (permalink)
JDM_Ricer
Member
JDM_Ricer's Avatar
JDM_Ricer is an unknown quantity at this point
Quote:
you dont need the rear axle. you can easly find a integra rear trailing arms and disc break set up i think the years ar 89-94 for the swap correct me if im wrong
JDM_Ricer is offline   Reply With Quote
Tags
1994 , 30 , 94 , change , civic , conversion , coupe , engine , honda , ingenswap , motor , pics , prelude , specs , swap
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
