Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-01-2009   #1 (permalink)
gwoodall
New Member
gwoodall is an unknown quantity at this point
AC belt removal 91 Civic 4-door DX
I can't figure this one out. The PS belt is simple, so is the altenator belt, but to get to the only bad belt, the alt belt, I have to remove the ac belt. Can anyone give some advice about how to get this belt out. Thanks
Gene
gwoodall is offline   Reply With Quote
Sponsored Links
Old 09-09-2009   #2 (permalink)
jworth
New Member
jworth is an unknown quantity at this point
Re: AC belt removal 91 Civic 4-door DX
To remove the A/C belt completely, you must remove the bolts from the lower motor mount. This will allow just enough sag so that the belt can be slipped out between the body and the mount. Now, if you only want the A/C belt removed from the main pulley, then all you need to do is loosen the tension on that belt. With the right extensions you can get to that bolt from the top. You'll have to, as I recall, loosen the lock bolt from the front, but then you adjust the tension from the top. Hope that helps.
jworth is offline   Reply With Quote
Old 09-20-2009   #3 (permalink)
ukrkoz
New Member
ukrkoz is an unknown quantity at this point
you have 91 dx, i have 91 lx
there should be no engine mount in your way, it was introduced on later models.
ac belt is the outermost belt and is tricky only because no one appears to be able to find a release bolt for the pulley. including myself.
release bolt for ac pulley is the center bolt for it. how simple is that! of course no one can figure that, who would have thought of this...
when you have it released, stand right above the ac compressor and look straight down at it.
in a small tunnel between PS bracket and engine block and that large bracket that runs from engine mount to the engine block, looking down, you should be able to see a 12mm bolt head. front corner of the compressor, next to engine block. that's ac tensioner bolt, tensioner slides up-down on a bracket. just turn it counterclockwise, pulley moves down, belt turns lose.
please, keep in mind that those engines are interference engines, timing belt must be done down every 60K miles. i just mention this cuz getting belts off is like half way done into this.
ukrkoz is offline   Reply With Quote
Tags
4door , 91 , 95 , 99 , ac , belt , civic , engine , forum , honda , mount , rear , removal , remove , removing , start , tensioner
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
