Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-25-2009   #1 (permalink)
shortys1519
New Member
shortys1519's Avatar
shortys1519 is an unknown quantity at this point
d16z6 hp ?s
i just swaped a d16z6 motor into my 92 vx hatch and took out the stock d15z1. i want to know if i have h/i/e how much hp can that give me? and maybe a little info on what i should do next. and dont say turbo please i already know thats the best way to get the most power To remove this ad, register today for free or log in if already registered!
__________________
d16z6 powered
shortys1519 is offline   Reply With Quote
Sponsored Links
Old 08-26-2009   #2 (permalink)
BIG RICH
Member
BIG RICH will become famous soon enough
Re: d16z6 hp ?s
here is the list of mods to my d16z6....it got me 151 all motor and 223 on the nitrous.....
• Engine Modifications.
GREEN Filter
DMS Custom Cold Air Intake
JG 72mm Bored Throttle Body
SKUNK2 Intake Manifold
AEM Fuel Rail
AEM Adjustable Fuel Pressure Regulator
FERREA Valve Springs and Retainers
5 Angle Valve Job
SUPERTECH 1/2mm Oversized Valves
Head Deck 30/1000
ZEX Street Cam
AEM Adjustable Cam Gear
Port and Polish
Bored 20 Over
11:1 Compression
JE Pistons
EAGLE H-Rods
Balanced and Blue Printed Block
Lightened Crank
ACT 6 Puck Sprung Stage 3 Clutch
ACT 8 lbs. Race Fly Wheel
NOLOGY High Energy Plug Wires
NOLOGY High Energy Ground Straps
PROTHANE Motor Mounts
NUMBER 1 Stainless Header
WALBRO HIFLO Fuel Pump
NX 75 Shot (Wet)
Programmed P28 ECU
2.5" Custom Header Back Exhaust
TURBO Resonator
__________________
THE NOT-SO-NEW NEW GUY
see the ride...http://www.civicforums.com/forums/46...mber-here.html
BIG RICH is offline   Reply With Quote
Old 09-07-2009   #3 (permalink)
k.civic.f4i
New Member
k.civic.f4i's Avatar
k.civic.f4i is an unknown quantity at this point
Re: d16z6 hp ?s
D16Z6
Found in
1992-1995 Honda Civic Si
1992-1995 Honda Civic EX, EX-V
1992-1995 Honda Civic ESi (European Market)
1993-1995 Honda Del Sol Si (US)
1993-1995 Honda Del Sol ESi (European)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Rod Length : 137MM
Rod/Stroke : 1.52
Compression : 9.2:1
Power : 125 hp (93.2 kW, 127 ps) @ 6600 rpm
Torque : 106 ft·lb (14.7 kg/m, 144 Nm) @ 5200 rpm
Volumetric Efficiency : 87.68%
Redline : 7200 rpm
Fuel Cut : 7411 rpm
VTEC Switchover : 4800 rpm[3]
Fuel Control : OBD-1 MPFI
Head Code : P08
ECU Code : P28
wikipedia does wonders
k.civic.f4i is offline   Reply With Quote
Tags
angle , big , cam , civic , d16z6 , honda , hp , make , motor , power , shot , street , turbo , valves , vx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
