Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-11-2009   #1 (permalink)
danielg
New Member
danielg is an unknown quantity at this point
92 Civic not starting
I have a 92 civic EX 1.6L. As I came to an idle at a stop light the car started running really rough, if I stepped on the gas it smoothed out. Anyways the car stalled when I put it into gear and I had to nurse it home by giving it lots of gas. When I went out to start it the next day it turned over fine but wouldn't fire at all. Once it started for a second (after it had been sitting and just died again). It will sputter if I hold the gas down all the way but it won't start. Here are the things that I have tried.
1) Jumpered the ECU to check for codes, nothing.
2) Pulled the distributor, checked and cleaned the contact points.
3) Pulled the plugs to check for spark. There was an orange spark.
4) Removed the valve cover and checked the timing belt. It was still tight.
5) Smelled the plugs after trying to start the engine. Definitely smells like gas.
6) The fuel pump definitely runs when trying to pressurize the system. I can hear it running and when I remove the intake line from the fuel filter there is good flow
7) Sprayed carb cleaner into the intake manifold and tried to start it. No change.
I'm at a loss on what to check next does anyone have any ideas?
Daniel
danielg is offline   Reply With Quote
Sponsored Links
Old 08-11-2009   #2 (permalink)
danielg
New Member
Re: 92 Civic not starting
Update.
I did a compression test and it didn't turn out well. From left to right the PSI numbers were 90,80,100,50. So one of the cylinders has very low compression. The car has never burned oil so it's probably not rings. Would a blown head gasket cause it not to start? Is that most likely the cause of low compression like this?
Old 08-12-2009   #3 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Go to a mechanic and tell him to check to see if you have Co2 in your coolant. Does your oil look like chocolate milk?
04 Honda Civic is offline   Reply With Quote
Old 08-13-2009   #4 (permalink)
tbohar
Senior Member
tbohar's Avatar
tbohar is on a distinguished road
If the head gasket is bad enough it could cause the car not to start. Were you blowing white smoke before it died??? That's an indication that your getting coolant where it's not supposed to go.
Take it to a mechanic or take the head off to see if it's the head gasket.
tbohar is offline   Reply With Quote
Old 08-13-2009   #5 (permalink)
danielg
New Member
It happened so suddenly that I didn't see any white smoke. I think I'll pull the head tonight so I can check the head gasket, as well as checking if the timing belt jumped a notch. Would a damaged head gasket be obvious by looking at it? I'll also take some oil in for analysis.
Thanks for the tips guys.
Daniel
Old 08-16-2009   #6 (permalink)
canolapole
New Member
canolapole is an unknown quantity at this point
I hava had similar issues with my 90 Civic not starting. I tracked it down (or so I'd like to think) to the main relay switch. Apparently its a known Civic hitch. Cost about 35 Canadian at Partsource.
canolapole is offline   Reply With Quote
Old 08-24-2009   #7 (permalink)
JDMEG4
New Member
JDMEG4 is an unknown quantity at this point
could it b your coil pak ?
JDMEG4 is offline   Reply With Quote
Old 09-02-2009   #8 (permalink)
mh3808
New Member
mh3808 is an unknown quantity at this point
Hey Daniel I've got a similar problem on my 93 LX. I'd like to know what you find out. I've heard it's probably either the distributor or main relay...thinking about changing the main relay first then the distributor if the relay is good.
mh3808 is offline   Reply With Quote
Old 09-06-2009   #9 (permalink)
04 Honda Civic
Super Member
Dont pull the head to check your head gasket try this instead. i highly reccomend this if you suspect a bad head gasket and are thinking of pulling the head this can save u alot more time if its not.
http://www.arrowheadradiator.com/hea..._leak_test.htm
Tags
92 , belt , change , civic , dies , filter , fire , fuel , honda , idle , rough , smoke , start , timing , white
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
