Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-07-2009   #1 (permalink)
troberts289
New Member
troberts289 is an unknown quantity at this point
1994 Civic Wont start and overheats!
Hello. So I have this civic. Its a 1.5 liter single overhead cam. I am having problems with it. It all started with it overheating. I jumped the fan so It would stay on constantly, and changed the the T-stat and temp sensor. Still overheated. Later I got to start it and the battery was dead, So i jumped it, and started right up. Then go to shut it off and it didnt start again, Just kept ctranking. Im prety sure the coil went bad on it. Im going to try the externam coil mod on it to make life easier. But the overheating thing is the real issue. After it didnt start I did a compression test on it. Compression was great. I pulled the distributor off to test the ignitor. I got a new one. Still didnt start. But the i noticed that it turned over really easy. Did another compression test on it and i hardly had anything!!! And from the time i tested it the first time until now It wasnt running. All i did was pull the distributor off!! I did a leakdown and it seemed like air was leaking through other cylinders, like pressure comming out the plug hole on the companion cylinder... What is going on here??? Did the head gasket blow or was about to and just let go without even running? bad waterpump? Rad clogged I have no clue! Any help would be great, I just dont get this at all.
Thanks, Tyler
troberts289 is offline   Reply With Quote
Sponsored Links
Old 09-12-2009   #2 (permalink)
wingnutCcoupe
New Member
wingnutCcoupe is an unknown quantity at this point
Re: 1994 Civic Wont start and overheats!
yeah, i know how u feal. i started looking around and i seen ur post. im having tha same prob on my 95 coupe. i took tha distrid all apart tested everything and its showing to b good. did u ever find out what was wrong on yours. please let me know. my email is wingnutcivic4dr@yahoo.com and my im screen name is tha same for yahooplease help
wingnutCcoupe is offline   Reply With Quote
Old 09-13-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
when you pulled the distributor off, did you set the ignition timing?
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 09-13-2009   #4 (permalink)
wingnutCcoupe
New Member
NO, what do i got to do
Old 3 Weeks Ago   #5 (permalink)
kycivic
New Member
1994 Honda Civic
kycivic is an unknown quantity at this point
im having a similar problem on my 94 ex. i changed the intake gasket and when i did it got coolant in the number 4 cyclinder. fixed all that then plugs weren't firing. replaced plugs, coil, rotor, cap, and wires. now its getting spark but it wont start. when it cranks the engine jumps. sounds like we have a common problem
kycivic is offline   Reply With Quote
Old 3 Weeks Ago   #6 (permalink)
gearbox
Super Moderator
sounds like timing issues (cam or ignition). maybe something got messed up.
__________________
www.lubecontrol.com
Member 1025782
Old 3 Weeks Ago   #7 (permalink)
kycivic
New Member
1994 Honda Civic
maybe it did. could ya explain how to check/adjust either
Old 3 Weeks Ago   #8 (permalink)
gearbox
Super Moderator
well ignition timing i think you need the timing gun and you shoot it in the hole near the trans case where the belt is turning. i really have no idea to be honest, my car doesnt use distributor. cam timing you check by making sure all the marks like up on the cam gear and crank pulley. its pretty complicated and you prolly need a repair manual.
__________________
www.lubecontrol.com
Member 1025782
Old 3 Weeks Ago   #9 (permalink)
tbohar
Senior Member
tbohar's Avatar
tbohar is on a distinguished road
Take it to a shop and get them to do it... You need special tools and it's a special procedure designated for special people... I had a 1992 honda accord with an H22A and I pulled the distributer without lining it up with marker and the same thing happened. Because of it I lost compression in 2 cylinders...
tbohar is offline   Reply With Quote
Old 3 Weeks Ago   #10 (permalink)
gearbox
Super Moderator
our 92 accord was very lucky, the distributor melted and it threw the timing off by about 20 degrees. engine would start, but would feel like nothing is happening when you gas it. thankfully the engine was perfectly fine once they timed it.
__________________
www.lubecontrol.com
Member 1025782
Old 3 Weeks Ago   #11 (permalink)
tbohar
Senior Member
tbohar's Avatar
yea gearbox i did the same thing except i screwed the engine unfortunatly... luck you that everything is okay.
Tags
1994 , 94 , 95 , accord , civic , crank , dx , forum , honda , ignitor , overheat , overheating , start , test , wont
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
