| Re: 1991 civic vehicle speed sensor code 17 problem On your 88-91 civic/crx you will have a cable going from your cluster to transmission speed sensor. You need to make sure the cable is all the way inside the sensor and being held with a retaining clip otherwise it will pop out of place and cause a check engine light if it doesn't read the speed properly. |
