Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-05-2009   #1 (permalink)
canolapole
New Member
canolapole is an unknown quantity at this point
Civic 90 Sedan Mirror
Hi everyone! My first message here about a Civic that doesn't have an opening or anything at all for a passenger side mirror (*photo attachment*). My question is - how do I fit in a mirror there? Do I need to bore a hole in the two triangular block plates? That seems so cumbersome!! Please let me know if there is a way to get a mirror there. To remove this ad, register today for free or log in if already registered!
canolapole is offline   Reply With Quote
Sponsored Links
Old 07-05-2009   #2 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: Civic 90 Sedan Mirror
Have you had the inside trim loose yet ??
If the metal has the holes already present... you would have the perfect template to drill them for a factory mirror.
CraigW is offline   Reply With Quote
Old 07-05-2009   #3 (permalink)
canolapole
New Member
Thanks for the reply. Did you mean the inside (window facing side) of the triangular block plate thats inside the car? If you did: no, I haven;t been able to do that. I took the panel off the door and tried to pull that blcok plate away but its very tightly held there, and I can't see any screws or anything.
Old 07-05-2009   #4 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Not sure how cover is held in place, Maybe you could pull edge back and look for mounting holes with flashlight.
Old 07-10-2009   #5 (permalink)
canolapole
New Member
Worked Had to grit my teeth and yank the plate off. It did NOT break, as I feared and didn't want to do put a lot of force. Now comes the part of finding a cheap mirrir
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
