Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-24-2009   #1 (permalink)
Vitamens
New Member
Vitamens is an unknown quantity at this point
94 EX Z6 civic missing ect....
Need help here guys... pretty car illiterate.. can do the basics but im stumped here... So the car is missing in every gear.. its lost power in every gear and the idle has went down from one to bout half a grand.. The missing is worse when its cold then warm but still pretty bad warm.. The worst time it misses is the more gas you give it.. if you ease into the gas it might initially miss a lil but it will pick up and slowly gain RPMS.. but it won't turn the rpms anything like it should.. If you have the car parked and give it gas it will twist the RPMS like normal but when it gets the load on it--it then starts to miss and sputter.. At about 1/8 of throttle it seems to do normal but if you give more then that MOST of the time it will kinda cut out and sputter and BARELY BARELY gain speed (better to just go back to 1/8 of the throttle). But to speak about the MOST.. sometimes you can give it about 1/2 throttle and it wont sputter out but the power still isn't there (doesn't climb in the RPM's like it should)... Also more info when you are giving it gas (going to the 1/8 of the throttle point) it will sputter just enough to notice then goes back to the pull.. but if you try and go about 1/4 throttle or more it will sputter and miss.
So i know its alot but any suggestions would be nice..
Like i said about plugs and wires have been replaced--ready to go from there.. i suppose distributor cap and button are next in line but if anyone has delt wit this and fixed it.. your input would be nice.. thank you.
Vitamens is offline   Reply With Quote
Sponsored Links
Old 07-27-2009   #2 (permalink)
94honciv
New Member
94honciv is an unknown quantity at this point
Re: 94 EX Z6 civic missing ect....
Yea,try rotor and cap if you have already changed plugs and wires.Check vacume lines for cracks,check all your electrical plugs.could be bad gas.How long has it been doing this?Might be a cat.converter.Just a few things I would check out.Check back and let us know.Good luck,Mike
94honciv is offline   Reply With Quote
Tags
1993 , 1995 , 94 , 95 , bad , civic , ect , forum , honda , idle , missing , modify , removal , sale , z6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
