Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-23-2009   #1 (permalink)
hondaguy
New Member
hondaguy is an unknown quantity at this point
89 civic adjustable proportioning valve
I have an 89 civic dx and want to install an adjustable proportioning valve.Does the original master cylinder have equal pressure at both lines,if not which lines do I want to run to the front brakes and which line do I want to run to my rear brakes?I plan on installing the valve on the rear brakes and runing the other line to a tee and then to both front brakes. To remove this ad, register today for free or log in if already registered!
hondaguy is offline   Reply With Quote
Sponsored Links
Tags
89 , adjustable , box , civic , cylinder , diagram , dx , fuse , honda , installing , master , prop , proportion , proportioning , valve
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
