Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-04-2009   #1 (permalink)
zonk
Member
zonk's Avatar
zonk is on a distinguished road
Send a message via AIM to zonk Send a message via MSN to zonk Send a message via Yahoo to zonk Send a message via Skype™ to zonk
92 civic dx hatch won't start
hi, I have a 92 dx hatch with a d15b7,the car has been sitting a year since I have been in Iraq and I just returned home to find it won't start. yesterday I replaced the fuel relay, and the fuel pump after turning the ignition and not hearing the fuel pump kick on but I am still not getting any fuel to the motor,tested the spark and I don't have any. the motor turns over fine, I have trouble shot it to the best of my knowledge, according to my neighbor I need to check the ignition control module or the ecm. I was wondering if anyone had a illustration as to wher ei might find the ICM, I have a suspicion it is somehwere around the distributor but I have never fooled with one good enough to take it apart to find it. than ks for you guys help To remove this ad, register today for free or log in if already registered!
__________________
92 civic dx hatch
zonk is offline   Reply With Quote
Sponsored Links
Old 06-06-2009   #2 (permalink)
zonk
Member
zonk's Avatar
Re: 92 civic dx hatch won't start
narrowed it down tot he #6 pin on the fuel relay wiring harness...now what that is, and how to fix it I have no idea
edit: no power is reaching the distributor and all fuses check out
__________________
92 civic dx hatch
Old 06-07-2009   #3 (permalink)
matthew7982
New Member
matthew7982 is an unknown quantity at this point
first of all, welcome back. Did you check the main relay under the dash? pin 6 should be the batt. voltage.
matthew7982 is offline   Reply With Quote
Old 06-07-2009   #4 (permalink)
matthew7982
New Member
also, i believe the ICM is located underneath the distributor cap (looking at the Haynes Manual for it, cause i have a 92 civic ex sedan). It seems like your problem is basically somewhere in the distributor maybe?
Old 06-16-2009   #5 (permalink)
zonk
Member
zonk's Avatar
checked the water pump ground, pin 6 has no power going to it, replaced the distributor . while checking I replaced the plugs, fuel filter, and plug wires. still not getting any spark or power to the fuel pump. only lights that are working on the dash are the battery and srs light.
__________________
92 civic dx hatch
Old 07-24-2009   #6 (permalink)
zonk
Member
zonk's Avatar
turned out to be a bad computer...was actually trying to sell the car on craigslist and he came to buy it....turns out he fixed it for a fifth of crown
__________________
92 civic dx hatch
Tags
92 , cap , civic , civicfuel , distributor , dx , fuel , hatch , honda , info , pump , relay , start , troubleshooting , willnotstarthowtofix92hondacivicuni1
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
