Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-01-2009   #1 (permalink)
leprosynachos
New Member
leprosynachos is an unknown quantity at this point
'89 EF motor options
I just came into an '89 Civic hatchback with a D16A6 in it (non VTEC) and am wondering about my options.
Is there a Type R head that'll fit on my motor? Or do I have to order a new mill online?
Any help greatly appreciated.
leprosynachos is offline   Reply With Quote
Sponsored Links
Old 06-02-2009   #2 (permalink)
wiltgen
New Member
wiltgen is an unknown quantity at this point
Send a message via AIM to wiltgen
Re: '89 EF motor options
no type r. you could put a d16z6 head or a d16y8 both are vtec heads sohc. othe rthen that youll have to swap a full bseries for anytype r head. or u could do a k series swap or a h22 swap
wiltgen is offline   Reply With Quote
Old 06-02-2009   #3 (permalink)
DieMaster
Senior Member
DieMaster's Avatar
DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light
Quote:
even better. you could buy my d16z6 head, do a mini-me swap, and swap to MPFI / OBD1 i got the parts too. evreyting but the mainifold. then u'd have the closest thing to a EG motor in a EF.
DieMaster is offline   Reply With Quote
Old 06-02-2009   #4 (permalink)
leprosynachos
New Member
Quote:
I was considering a Mini-Me Swap with a D16z6 head.
What all would I need to buy to make the conversion work?
Old 06-02-2009   #5 (permalink)
DieMaster
Senior Member
DieMaster's Avatar
well i can assume yours is DPFI? 2 injectors vs 4. u cant do shit with that setup. not even chip it. i would convert to MPFI first. i cant think of a ECU that isint MPFI and VTEC. obd0 or 1 dosent matter as both famalys have, or ecu's that can be chiped to be, vtec ECU's.
actualy i just read the post and u said u have a A6 motor? in a hatch? must be the SI hatch. if thats true your allready MPFI. u lucked out bro lol.
the easiest would be staying OBD0 and getting a PS9 ECU. thats a automatic 90-91 EX and was the only ecu to run the A6 engine as a automatic for the sedans. there are porgrams u can use (chip the ecu) to make the auto output (one wire vtec) into a VTEC output. this wont be a stock program though so u may not pass your emmissions test. OBD1 would need a P28 ecu (92-95 EX/SI) but as there the single most popular ecu, they can be tricky to get / expensive. i got some P06 witch is OBD1 92-95 DX/LX and can be chiped and have the VTEC componets added to make a P28. I recomend going OBD1 as there are FAR more options of tuning especaly with a mini-me swap.
if u wanted OBD1 u need 3 main parts. OBD1 ECU, Distributor, and 4 wire O2 sensor. First the ECU is diffrent as it's is 16bit vs 8 bit. better resolution. like going from standard to HD tv. better control and mesuring. Second is because of the first the Distributor has the 3 sensors needed for the PGMFI system. these sensors have double the pulses on OBD1 vs OBD0. and lastly u need a 4 wire O2 as the ECU has a heater output for the heated O2. this is needed for proper poweroutput and on that old of a car it couldent hurt to change it anyway.
i can sell you the head with the obd1 distributor allready atachehed. i even have the OBD1-OBD0 harness and the Distributor Harness as there plugs are diffrent. what i DONT have is the manifold (your MPFI dont worry about it) and the 02 sensor.
if u want to read further or re-read what i just typed out go to PGMFI.org
Old 06-09-2009   #6 (permalink)
hondaguy
New Member
hondaguy is an unknown quantity at this point
I hate to steal this thread but I have the same question but I have a d15b motor in an 89 civic dx.I also was thinking of the mini me swap,do I have to do the same but change to mpfi?What is the horsepower and torque rating (roughly) on a mini me swap?
hondaguy is offline   Reply With Quote
Tags
89 , 90 , civic , code , d16z6 , distributor , ef , honda , mini , motor , obd1 , options , pics , swap , wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
