Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-23-2009   #1 (permalink)
country
New Member
country is an unknown quantity at this point
95 dx manual running rough after 2nd start
I have a 95 dx manual that is running great, except that when I go to restart it after I've stopped for food/gas/anything that only takes a couple of minutes.
The problem I've noticed is that it starts and runs really rough and seems like it wants to die. I can power through it and once I get to about 20-25 mph it starts to run normally again. I just had the thermostat replaced because it was overheating. While that was being done my mechanic decided to clean the "throttle body" (that little valve that regulates the air flow).
I don't think the the rough starts were caused by him doing that. But wtf do I know.
So cliffs: no problem starting cold, once warmed up and I turn the car off the engine runs VERY rough.
country is offline   Reply With Quote
Sponsored Links
Old 03-23-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: 95 dx manual running rough after 2nd start
almost sounds like a vacuum leak or the guy forgot to plug something in around the throttle body area. look around the engine see if everything looks connected.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 03-25-2009   #3 (permalink)
country
New Member
It could be a vacuum leak, but I did not see anything that looked disconnected.
Old 03-30-2009   #4 (permalink)
country
New Member
Ok, so I took it to my mechanic and he looked at the IACV and FITV. The problem did not go away. He is "thinking" that it could be a small leak in the head gasket. Which, with the cost of the radiator and labor will bring the total for this trip up to around $1000 and possibly above.
I am thinking its not worth it. Any thoughts.
Old 03-30-2009   #5 (permalink)
gearbox
Super Moderator
are there any stored engine codes? its possible that the headgasket has a small leak allowing coolant into the cylinders which is then being burned and causing misfires. could be something else tho too.
__________________
www.lubecontrol.com
Member 1025782
Old 05-28-2009   #6 (permalink)
country
New Member
Well as it turns out the head is definitely leaking. So I pulled the head off and am taking it to a mechanic to find out how much the head is warped. I have all of the new gaskets already, high temp thread locker, and some kind of silicone lube. I am going to be buying new head bolts and gasket glue.
Does anyone know what the sequence is for tightening down the head bolts, my service manual doesn't say.
Tags
1995 , 2002 , 95 , civic , cold , die , honda , lx , rough , running , runs , started , starting , starts , turns , why
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
