Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-15-2009   #1 (permalink)
9999Honda
New Member
9999Honda is an unknown quantity at this point
Just replaced my distributor and my car still wont start. Appreciate any advice.
Hi. My 1994 civic stalled and I had it towed to my house. My brother and I replaced the following parts fuel filter,spark plugs and wires; we replaced the s-plugs because two of the plugs had oil on them when we checked them, so we also replaced the outer ring gasket, tube seals, air filter and the whole distributor meaning not just the cap and rotor. When we went to start the car it now jumps when trying to start but still does not turn over. We check the main relay and it's fine. Would appreciate any help. Thank you.
Also... I just had my fuel pump replaced a couple of months ago.
9999Honda is offline   Reply With Quote
Sponsored Links
Old 03-19-2009   #2 (permalink)
Hondaddict
New Member
Hondaddict's Avatar
Hondaddict is an unknown quantity at this point
Re: Just replaced my distributor and my car still wont start. Appreciate any advice.
If its not your main relay it may be your comp I had a 90 si hatchback do that same thing was gettin gas but wasnt firing so we replaced the distributor still wouldnt start found out my main relay was bad and my cpu was also bad so check your cpu hope that helps
__________________
If you love your car thats all that matters and I love my civic
Hondaddict is offline   Reply With Quote
Old 03-25-2009   #3 (permalink)
9999Honda
New Member
Main relay is good and so is CPU. I just tested my battery and it's at 11.6v I'm going to replace it and see if that'll do it. Any other suggestions?
Old 03-25-2009   #4 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
check fuel pressure
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Tags
5th , 95 , bad , car , civic , distributor , gen , honda , ow , pictures , plugs , replaced , spark , start , wont
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
