Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-24-2009   #1 (permalink)
Pistol1583
New Member
Pistol1583 is an unknown quantity at this point
1991 civic SI rough idle poor mileage
I have a 91 honda civic SI 1.6 with about 90,000 on the motor. I have noticed a rough idle and poor gas mileage. I did a little tune up with new plugs, new plug wires, vacume lines, air filter, and injector cleaner. I have also noticed when i come to a stop and push the clutch in the cars rpms drop to about 200 and it almost stalls. I also did an O2 sensor about 1 1/2 years ago. I dont think its the gas because i use the same mobile station that i have gone to for years. any tips?? To remove this ad, register today for free or log in if already registered!
Pistol1583 is offline   Reply With Quote
Sponsored Links
Old 02-24-2009   #2 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Re: 1991 civic SI rough idle poor mileage
I have the same problem Rough Idle try cleaning ur IAC. Didnt work for me but maybe it will for you.
04 Honda Civic is offline   Reply With Quote
Old 06-27-2009   #3 (permalink)
sp44
New Member
sp44 is an unknown quantity at this point
I have the exact same problem on a 92 EX. Anybody find a fix?
sp44 is offline   Reply With Quote
Old 07-02-2009   #4 (permalink)
Silver06hemic
New Member
Silver06hemic is an unknown quantity at this point
Quote:
X2..... also give the TB a really good clean.... run the motor and spray it down whilst raising the revs to keep from stalling. The TB's on any car get gummed up over time... it doesn't take much cause a rough idle. The IAC will cause a constant 'searching' for revs (ie: a rev up and down up and down at an idle) and also in extreme conditions can cause stallouts. It's always good to give it a good spray down as well.
Silver06hemic is offline   Reply With Quote
Old 07-12-2009   #5 (permalink)
Monotech
New Member
Monotech is an unknown quantity at this point
Change your fuel filter,cap & rotor. To raise the idle, you have an idle adjustment screw on top of your TB. The wild idle will more likely be due to fast idle valve, just remove it and remove the 2 small phillip screws and remove the cover then tighten up the big plastic valve clockwise and whalah problem fixed.
Monotech is offline   Reply With Quote
Old 07-19-2009   #6 (permalink)
revr63ed7
New Member
revr63ed7 is an unknown quantity at this point
A d16a6 doesnt have a thermal fast idle valve to screw the plunger.
revr63ed7 is offline   Reply With Quote
Old 07-21-2009   #7 (permalink)
sp44
New Member
For me a new PCV valve fixed it!
Tags
1991 , 2005 , 91 , civic , diagram , honda , idle , idling , low , makes , mileage , o2 , rough , sensor , si
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
