Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-16-2008   #1 (permalink)
cyapeepn
New Member
cyapeepn is an unknown quantity at this point
Question 89 civic 1.5 will not start after driven
After car has been started and driven once its turned off it takes about 3 minutes before I can start it again. My wifes friend has the exact model with the exact problem. I changed the cap & rotor, plugs & wires. No luck. Anyone else that has had this trouble, can you please let me know what you did to correct it? To remove this ad, register today for free or log in if already registered!
cyapeepn is offline   Reply With Quote
Sponsored Links
Old 02-19-2009   #2 (permalink)
Civvyftw11
New Member
Civvyftw11 is an unknown quantity at this point
Re: 89 civic 1.5 will not start after driven
100% sure its your main fuel relay.
its a pretty easy fix but its pricey, the main fuel relay is located under ur fuse panel to the very left of the drivers side. what you gotta do is take out your coin box, take off the fuse panel and then there will be another 10mm bolt right infront of you connecting most of the panel together i suggest taking this bolt off because it allows for more movability. Anyway once thats done its time for the hard part, this entire thing has to be done upside down. Unscrew your hood release again for an easier access and to the left of the hood release will be a 10mm nut. This is the only nut you have to unscrew but you need a smaller ratchet in order to unscrew it, also like mine yours may be some what rusted out so you have to giver but not too hard or else it breaks. then once thats done you have to maneuver around to get the main relay out and replace it. Depending on how much longer you want to have the car you can buy a used one. Mine cost around 95$ cad.
http://www.tegger.com/hondafaq/mainrelay.html
thats a good site if u need some more help
Civvyftw11 is offline   Reply With Quote
Tags
main , relay
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
