Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-22-2008   #1 (permalink)
Warmmushroom
New Member
Warmmushroom is an unknown quantity at this point
1991 Civic Won't Start....Help!!!
I have a 91 civic hatchbach that wont start at all...this is all the info on the situation any help would be great. When I turn the key I can hear the fuel pump engage and a click from under the dash(it is defn' under the dash not the starter solenoid) and then nothing...before this happened I had no check engine light and no problems at all. The car sat for 2 months and when I went to start it this is when the problem started. I have checked the starter solenoid, if I jump the terminals the starter engages and the car starts no problem so not a starter issue. Checked the battery cables all good, battery is new and works fine, i have tested it and it will start my chevy V8 truck. The main realy and starter relay were tested and replaced for good measure. The clutch switch is also not the problem I even disconnected it and jumped the wires to by-pass it. Still no start. All other electrical works perfectly radio, lights etc. If i jump the starter and start the car it runs and drives perfectly just wont start with the key...I am almost out of ideas, could it be the ignition switch? If so shouldn't the rest of the electrical system not work? To remove this ad, register today for free or log in if already registered!
Warmmushroom is offline   Reply With Quote
Sponsored Links
Old 10-04-2008   #2 (permalink)
dspeedcrazy02
New Member
dspeedcrazy02 is an unknown quantity at this point
Re: 1991 Civic Won't Start....Help!!!
do you have a aamco close by? we took my 91 dx there and they test 4 pretty much everything!
dspeedcrazy02 is offline   Reply With Quote
Old 10-12-2008   #3 (permalink)
heretohelp
New Member
heretohelp is an unknown quantity at this point
lol i regesterd just to tell you this
i had the same prob with my 5th gen. if its a 5spd its most likely your neutral safety switch i can tell you how to fix it just add my msn zaksonsythe@hotmail.com
heretohelp is offline   Reply With Quote
Old 11-24-2008   #4 (permalink)
soltero
New Member
soltero is an unknown quantity at this point
Quote:
Originally Posted by Warmmushroom View Post
...could it be the ignition switch? If so shouldn't the rest of the electrical system not work?
It could in fact be the ignition switch. I had a similar problem and at first thought that it was being caused by a faulty fuel pump. Two different Honda mechanics (who both work at Honda dealerships) on justanswer.com recommneded checking the ignition switch. To make a long story short, a mechanic found that, once started, as long as he held the key at a slight up-angle, it would continue to run. Let go of it, and it would die every time. I changed out the ignition switch and it solved the problem. Hope this helps and let us know how it goes.
Btw, the part I used was this one from O'Reilly Auto Parts.
- soltero -
soltero is offline   Reply With Quote
Old 03-06-2009   #5 (permalink)
NitroTC3
New Member
NitroTC3 is an unknown quantity at this point
There is also a round piece of small rubber that sits up in the arm of the clutch peddal. if this is missing because it could desintegrade the car would not start. this rubber pice is what engages the switch thats behind the clutch under the dash.
It cost 3 dollars to replace. The brake peddal has the same setup with the small rubber piece and a switch.
NitroTC3 is offline   Reply With Quote
Tags
1991 , 2000 , check , civic , clutch , codes , engine , honda , ignition , light , problem , start , switch , wont , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
